 Post subject: Check the time hard disk is remove
PostPosted: October 8th, 2012, 5:18
I've server with 3 hard disk. Suddenly, 1 disk is unplugged and remove. Are there software or tool can check how long the disk is remove. Can anyone help me to solve this problem. Thanks you so much
 Post subject: Re: Check the time hard disk is remove
PostPosted: October 8th, 2012, 5:47
Servers SHOULD have LOG server Linux/Win
start from there...
good luck
PostPosted: October 8th, 2012, 6:03
@meoconhs2612,
A disk which has been removed, cannot tell you anything about how long it was removed. As einstein9 said, you would need to investigate the server's logs for that situation.
However I wonder if you really mean that a disk was "suddenly" removed; or whether you mean that you already have a log which says that a disk was removed, when it wasn't actually removed (I've seen that situation with some RAID controllers).
IMHO you need to give much more clear info about the hardware and software configuration & how you know that a disk was "suddenly" removed. What/who is telling you that a disk was removed? Do you believe that source of information? Why do you care how long the disk was removed?
