 Post subject: what old interface is this ?
PostPosted: June 25th, 2014, 20:36
what old interface is this ? :)
i need to recover some pictures from this old camera (internal memory) but i cant find the right cable...
thanks for all your help
cheers :)
 Post subject: Re: what old interface is this ?
PostPosted: June 25th, 2014, 21:00
Hi, best bet is to search for a manual for the camera, or at least post what model camera it is. Some old cameras have custom data/charge cables.
Edit again, New Mini USB 4-Position
https://kb.wisc.edu/showroom/page.php?id=3113
or a better picture (not sure if they are slightly different)
Mini USB 4 Pin
(USB Mini-B)
4.5mm x 3.5mm
http://www.cablechick.com.au/content/cable-connector-chart/
PostPosted: June 26th, 2014, 0:03
Thanks for your help
Mini USB 4 Pin
It seems that it is this one :D lets see a cable for this
PostPosted: June 26th, 2014, 2:47
My old Nokia 1600 phone has a connector like that, as does my old Kodak DX4530 camera. It seems like you shouldn't have too much trouble finding a cable.
PostPosted: June 26th, 2014, 3:51
thanks for your help...
this connector has been soldered again to the machine from a friend
i have photos here dated from March 2007 to recover (Prom Night)
PostPosted: June 26th, 2014, 5:15
Well if you cant get them, send it to me and I will recover from chip !
PostPosted: June 26th, 2014, 9:17
lets see if the connection works as expected :)
PostPosted: June 26th, 2014, 16:24
What is the model of the camera? I may be able to find a service manual with circuit diagrams ...
PostPosted: July 27th, 2014, 15:35
hi fzabkar i will see when i get home in a few days :)
will try to buy the cable from ebay, im able to see the pictures just fine like when i take them in 2007 so lets see if the interface works like the rest of the camera after the soldering
thank you
PostPosted: January 19th, 2015, 7:52
thanks again for all your help
recovered today the pictures using the Interface from the camera that was broken before.... after re-soldering is working again
PostPosted: January 19th, 2015, 9:08
Great! Always good to see a win :-)
