Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
 Post subject: Re: Lenovo P15
PostPosted: September 14th, 2026, 0:02
Hardcore Games wrote:
I use a large table for my gear, so top loaded disk enclosures are convenient
I have several laptops besides the P15 I have been using. Machine has a 4K OLED LCD so the machine is good for movies etc.
I have installed two M.2 SSDs in the machine but I might get larger capacity ones for more convenient entertainment
What brand of table do you use?
PostPosted: September 14th, 2026, 10:42
My table is a standard office table I got from an auction some years ago. The table is 60 inches wide so there is lots of room for several enclosures along with room for my laptop. The table has no branding on it.
I use excel extensively for data processing. Most of my storage is for games which I get lots of for free.
Excel has a lot of advanced functions for statistics. I use these a lot and my CPU with 12 threads does feel the load.
PostPosted: September 15th, 2026, 9:16
I honestly don't know who is trolling who
PostPosted: September 15th, 2026, 10:09
I never trust those.
PostPosted: September 15th, 2026, 10:10
Sliding drawers are convenient, as I can pull them out and store things conveniently
I must try those some day
PostPosted: September 15th, 2026, 13:42
Finally got a screenie for the SK Hynix SSD I have
PostPosted: September 16th, 2026, 0:22
While the general health status reads Good 100%, there is a critical hardware alert hidden in the S.M.A.R.T. values down below: ID 0E (Media and Data Integrity Errors) has a raw value ending in 1. This means the drive has encountered a physical uncorrectable data block error. It is a sign of early physical degradation, not a firmware bug.
However, the 80003E00 firmware itself has documented issues, primarily concerning inefficient power distribution and thermal stability management under specific Windows power states.
The Known Firmware Vulnerability:
The older 8000x-series firmware releases for the SK Hynix PC401 are prone to:
Power-state mismatch: The SSD can fail to wake up properly or drop off the system bus during deep sleep transitions.
Thermal throttling lag: Slow power-state shifting can cause the controller to stay hotter than intended during intensive tasks.
Recommended Solution: You need to patch the storage microcode to resolve the software bugs and prevent further data correlation issues.
You should run Seatools asap on this one as well. Multiple times a day. on every drive you own. do it now.
1) Back Up Everything: Before modifying storage firmware, back up your critical documents immediately. The 0E error indicates data corruption may happen next.
2) Download the Fix: Update your drive to the final recommended version, 80007E00. If you are using a branded machine, you can source this utility through the Dell PC401 Storage Firmware Update page or your specific laptop manufacturer's driver portal.
3) Execute the Update: Close all running applications, launch the update tool as an administrator, choose the target drive, and allow the system to reboot to flash the new microcode.
Please let me know: Is this SSD your main boot drive? Are you currently encountering any Blue Screen errors (BSODs) or system freezes? Knowing this will help narrow down if the single media error requires a complete drive replacement.
PostPosted: September 16th, 2026, 8:53
I am not using that SSD as it has too many hours on it. I was using to get the P15 BIOS updates. I then I switched to a KIngSpec NX 2TB for my main system SSD.
PostPosted: September 17th, 2026, 0:59
Have you had the random Nibble flip issue that occurs with these drives? Apparently when you stuff these drives into a P15, The algorithm of the forum chatbot can mess up and flip a few of the most significant nibble to least significant. As there seems to be almost no significance in this whole thread, I think yours has this Issue.
PostPosted: September 17th, 2026, 14:05
I found on the SK Hynix site a tool for SSD so once I put the old SSD into a TB4 enclosure I should be able to update the SSD firmware. I am not sure about SK Hynix as this is not widely seen at local vendors as WD/SanDisk slugs it out with Chinese brands.
I probably will get some more M.2 TB4 SSD enclosures as these seem to be convenient. This sell for under $100 CAD.
CrystalDiskInfo also can read the SSD interface speed up to PCIe 4.0 which suggests TB5 enclosures are not needed for older SSD use. TB5 is more oriented around 8K panels than PCIe 5.0 SSD products.
Power on hours for SSD seem less concerning compared to mechanical hard disks. Some of my old disks have racked up 30,000 hours or so from when I used to used them in a desktop before I moved to laptops exclusively.
PostPosted: September 17th, 2026, 18:23
can you list some more random facts about how your P15 interacts with SSDs and 8K panels using some slang filler words
PostPosted: September 18th, 2026, 13:24
I only have 4K OLED on my P15 so my machine is not able to run 8K panels. My TB4 hub is also built around 4K panels. 8K24 might work but not with HDR10 color etc. TB5 is faster at 80 gigabits and it supports 120/40 gigabits in an asymmetric mode to handle 8K60.
Long ago SDI was used when HD was a thing using D5 tape decks etc. Now my TB4 enclosure shows PCIe 4.0 speeds with a suitable SSD. PCIe 4.0 is fast enough to handle 8K RAW video but my i7 CPU is not powerful enough to handle that level of performance.
8K is extremely demanding. TB5 machines are $4 grand and up. Red cameras are $50 grand and up. Red uses CF Express cards which can hold maybe 15 minutes of footage. Last time I was on their site evidently Nikon now owns them.
PostPosted: October 31st, 2026, 16:20
I have also ordered the RTX 5000 card for my P15 which perk up overall performance. The RTX 5000 packs some 11 TFLOPS FP32 so it should play games at 4K UHD fine.
SSD prices are so high the GPU seems like bargain. The RTX 5000 has 16GB VRAM which is typical with modern cards out there,
PostPosted: October 31st, 2026, 21:41
By my calculation you must be around 70 years old.. Spider Solitaire does not need that kind of perfermance!
PostPosted: November 1st, 2026, 19:20
The latest Halo game is more demanding
PostPosted: November 2nd, 2026, 5:10
Spider solitaire is more mentally demanding, but you wouldn't know that
PostPosted: November 2nd, 2026, 15:24
I play a game called Flotsam and it is so complicated to survive that 99/100 tries a doomed
PostPosted: November 2nd, 2026, 18:25
Why would a bot play a game?
PostPosted: Yesterday, 5:12
to entertain itself between forum visits?
to make use of otherwise wasted cpu cycles?
:D
PostPosted: Today, 1:58
The dual M.2 layout is the practical part of this machine for me; splitting boot and working storage keeps a full drive from taking the whole system down. One thing to verify on a gen 1 is how the second slot is wired, since lane sharing with TB3 can vary by configuration. Also worth checking whether the 4K panel runs at 60 Hz on battery versus AC, as power settings sometimes throttle it. Have you confirmed both slots negotiate at full speed with your drives installed?
