 Post subject: WD HDD SF Monitor Card Pro - is it a dud?
PostPosted: November 17th, 2026, 12:46
This "pro" card is touted by Dolphin as an aid in the refurbishment of WD HDDs:
https://dolphindatalab.com/product/wd-hdd-sf-monitor-card-pro/
https://dolphindatalab.com/wp-content/uploads/2016/05/wd-hdd-sf-monitor-card-pro-1.jpg
https://dolphindatalab.com/wp-content/uploads/2016/05/wd-hdd-sf-monitor-card-pro-2.jpg
WD HDD SF Monitor Card Pro is the latest product from Dolphin Data Lab helping those who are refurbishing Western Digital hard drives to monitor their offline selftest process and this will tremendously save refurbishing time and enhance users’ refurbishing success rate.
After users run ARCO optimization online for the drives to refurbish, users can remove the drives and connect to external power supply to run offline SF test. But some offline Selftest might fail due to head issue or some unknown hdd inner health issue and at this time, users don’t know and like normally can only wait for some time to remove the hdds from external power supply and connect back to tools to find out the SF logs and find out which step was going run.
If users refurbish several hdds at the same time, this is not a problem but if users refurbish tens of, scores of, hundreds of, what to do? Dolphin WD HDD SD monitor card displays lively the current SF process, if error, the card pro. display the error code and users can easily find out the reason in the first time and handle the refurbishing properly.
To me, it looks as if Dolphin have connected the 5V output to ground. That's a dead short. I suspect that the 8-pin IC is a dual P-channel MOSFET which switches the 5V and 12V rails under control of the main microcontroller.
SATA pin #4 at the output side appears to be controlled by the microcontroller. I would have expected that SATA pin #3 (Power Disable) would be the correct pin.
Is this design a dud, or am I missing something? Has anyone actually bought this product?
https://pinoutguide.com/Power/sata-power_pinout.shtml
 Post subject: Re: WD HDD SF Monitor Card Pro - is it a dud?
PostPosted: November 17th, 2026, 13:08
Perhaps SATA pin #4 is an input that signals to the microcontroller that a HDD is present? When no HDD is attached, this pin could be pulled up to Vcc. Otherwise the HDD would ground this pin.
Users browsing this forum: No registered users and 6 guests
