General discussions, chit-chat
October 30th, 2007, 7:32
I have a failed Fujitsu MHS2040AT with 4 heads, but all donor parts I have available have only 3 heads, I can see no specific revisions or information that differs between the two disks and no way to know if I have compatible parts. I have had a similar problem with a Fujitsu MHV2080BH. Is there any way to determine the head configuration before I order any more parts which I cannot use?
October 30th, 2007, 10:53
Hi hddguy,
yes, .... just read 04h head map module.
October 30th, 2007, 12:14
I had just the same problem with a Fujitsu drive.
Coffeebean: in the damaged drive you can check head map by opening the drive, but how can you check that on a donor drive you're searching?
October 30th, 2007, 13:19
It is identifying the head map on a donor I need. Hope there is a way for this!!
October 30th, 2007, 13:54
hddguy wrote:It is identifying the head map on a donor I need. Hope there is a way for this!!
04h will give both donor and patient.
also, quite often "non-detecting" patient even allows to read 04h,
October 31st, 2007, 4:47
Coffeebean: but imagine you're searching for a donor drive for a case like this. How will know what parameters to search in order to have the same head map as patient drive?
October 31st, 2007, 6:03
Hi dmarques,
I answered the question twice.
So, take some Fujitsu drives and read 04h and figure it out.
October 31st, 2007, 18:50
Hi Guys,
I think there is an indication in the serialnumber of the drive, just as with the maxtors.
However, for a Fujitsu, it was the 4th or 5th character i think.
I'm not in the office, so i cannot verify it now, but i found out this was correct with the drives in my posession.
Best regards,
Dobre
November 2nd, 2007, 11:31
That would be nice to know what's the character.
