General discussions, chit-chat
WD400JB-00FSA0 dcm=HSBHCTJCA 30 nov 03
February 9th, 2009, 5:40
hello folks
this drives clicks, not recognized at all,
we like to recover the data.
can anyone help,
with lot of appreciations
ephraim
Re: WD400JB-00FSA0 dcm=HSBHCTJCA 30 nov 03
February 10th, 2009, 10:25
IS THERE ANY BODY THAT MIGHT GIVE A GOOD ASSISTANCE IN ORDER TO RECOVER THE DATA FROM THIS HDD?
TKS A LOT
EPHRAIM
February 10th, 2009, 13:35
See my answer to previous post. Same applies.
February 10th, 2009, 18:08
Something tells me both drives were in one system and you got a pretty good shock to you computer frying both drives. It is possible that both drives will just need a board swap, but you will also need some solder skills to swap the ROM chips. If the data is important i would recommend to send the drives to a pro. Maybe someone can give you a deal if you send in both.
February 11th, 2009, 2:35
can u tell me pls where is the ROM chips located?
tks a lot
ephraim
February 11th, 2009, 6:58
The forum search feature can be your best friend...
February 11th, 2009, 10:06
HELLO thatdellguy
TKS FOR YOUR GOOD WILL.
I MADE A SEARCH BUT THERE ARE LOT OF PAGES.
CAN U E MORE SPECIFIC.
BRGDS
EPHRAIM
February 11th, 2009, 10:49
thatdellguy, come on be reasonable. :twisted:
ephrahim's time is very valuable to read that many pages.
Can you give him a detailed instructions? :mrgreen:
February 11th, 2009, 11:14
hi harddrivespecialist
tks a lot for your understaning
brgds
ephraim
maybe u know where the ROM chip is located?
February 11th, 2009, 17:04
I'll take pity on you: position U12. Be warned: if you don't have the soldering skills you could ruin chances of recovery. Good luck.
February 12th, 2009, 2:50
HELLO msurgeon
I'LL TRY NOT TO DISSAPOINT U.
TKS A LOT. KEEP FINGERS FOR ME
BRGDS
EPHRAIM
February 12th, 2009, 3:26
Beside spoon feeding, if you don't succeed - likely - pm me if you want to send the drive to recover data. Of course if it was not tampered too much.
