 Post subject: New ST31500341AS not detected in BIOS - Limit Speed - Jumper
PostPosted: February 20th, 2009, 13:01
Hello!
The Seagate ST31500341AS, 9JU138-302, Firmware CC1H is not detected by the BIOS (VIA VT8237, BIOS Version 4.97).
Is this a bug of the firmware (a SAMSUNG 320GB HDD with 3.0 GBit/s SATA is detected without any problems)?
Is there a jumper setting for the speed limit (1.5GBit/s) available?
I tried already tried without success:
http://www.digitalanime.com.br/sea/connector.jpg
I know that the VT8237 chipset has some limitations.
Any ideas?
Thnx.
Wiesl
 Post subject: Re: New ST31500341AS not detected in BIOS - Limit Speed - Jumper
PostPosted: February 20th, 2009, 16:14
The picture has correct settings for SATA 1.5Gb/s
There is something else prventing drive from init
PostPosted: February 21st, 2009, 3:53
Is this valid for any revision of the drive (9JU138-302)?
Mine hasn't any jumper settings on it, there were revision were the drive had the jumper settings on it.
Thnx
Wiesl
