 Post subject: Clean room
PostPosted: March 20th, 2009, 16:08
Can some one give some info about cleanroom class 100.
About specification have a lot of info, I am interested about companies related with this technology.
 Post subject: Re: Clean room
PostPosted: March 21st, 2009, 20:37
A cleanroom is an environment, typically used in manufacturing or scientific research, that has a low level of environmental pollutants such as dust, airborne microbes, aerosol particles and chemical vapors. More accurately, a cleanroom has a controlled level of contamination that is specified by the number of particles per cubic meter at a specified particle size. To give perspective, the ambient air outside in a typical urban environment might contain as many as 35,000,000 particles per cubic meter, 0.5 μm and larger in diameter, corresponding to an ISO 9 cleanroom
Cleanrooms can be very large. Entire manufacturing facilities can be contained within a cleanroom with factory floors covering thousands of square meters. They are used extensively in semiconductor manufacturing, biotechnology, the life sciences and other fields that are very sensitive to environmental contamination.
The air entering a cleanroom from outside is filtered to exclude dust, and the air inside is constantly recirculated through high efficiency particulate air (HEPA) and/or ultra low penetration air (ULPA) filters to remove internally generated contaminants.
Staff enter and leave through airlocks (sometimes including an air shower stage), and wear protective clothing such as hats, face masks, gloves, boots and cover-alls.
Equipment inside the cleanroom is designed to generate minimal air contamination. There are even specialised mops and buckets. Cleanroom furniture is also designed to produce a minimum of particles and to be easy to clean.
This is clean room specification right off the Internet if you need more answers you can search under Industry standards for clean rooms, class 100 clean room, specifications for clean room standards. it is very easy to find your answers this way
209e.pdf [167.51 KiB]
Downloaded 1556 times
Iorana Haraharaini
