 Post subject: Disk list is not populated
PostPosted: January 27th, 2010, 16:58
I am running Windows Vista. After downloading HDDScan I started the program and there was no list of disks although the pull down showed 4 disc icons, (screen capture attached). All of the task choices were greyed out as well.
Thanks for any help
rich
 Post subject: Re: Disk list is not populated
PostPosted: January 28th, 2010, 3:10
Did you try starting it as Administrator? (Right click --> run as)
Best regards,
Zuujin
PostPosted: January 29th, 2010, 9:03
Zuujin
Thanks for responding. Yes I did try starting it "as administrator", and the result was the same. Any other suggestions?
thanks
rich
