 Post subject: Can a drive that has bad blocks and or bad sectors be used??
PostPosted: October 17th, 2011, 12:08
If I have a drive that has been wiped and erased and still comes up with WARNINGS and or ERRORS can it still be used to load an operating system on it???
Also how reliable would the drive be???
Thanks for any advice.
P.S. Been a long time since my last post.
Low flying aircraft the sound of freedom.
 Post subject: Re: Can a drive that has bad blocks and or bad sectors be us
PostPosted: October 17th, 2011, 12:40
Short answer/recommendation: no
PostPosted: October 17th, 2011, 13:45
As drc said, the likely recommendation is not to use it.
However if I was in a situation where I had to consider that possibility, I would at least try to diagnose what type of problem the drive may have (not all errors are caused by the drive, but can be the consequences of a problem elsewhere), and would also depend on exactly what was meant by "WARNINGS and or ERRORS" in your description.
Users browsing this forum: No registered users and 90 guests
