 Post subject: How many rounds does the Gutmann method support?
PostPosted: September 23rd, 2011, 20:22
I understand that is not a DBAN, or a forum such as Gutmann.
Will someone please answer this question? Thank you.
How many rounds does the Gutmann method supports? I understand it's 35 passes for 1 round. Does anyone know the exact rounds it goes up too, or would the rounds be unlimited where there is no number?
 Post subject: Re: How many rounds does the Gutmann method support?
PostPosted: October 27th, 2011, 18:28
35 passes per round. You can do as many rounds as you wish. But after the first pass your data is unrecoverable on standard media. If you're using a flash, even 35 passes isn't enough because of wear leveling.
