 Post subject: Clickfree automatic Backup remove VCD
PostPosted: February 6th, 2012, 13:54
I need to remove de virtual CD from my clickfree HDD.
Partition magic, Gparted, and other partition tool dont work
 Post subject: Re: Clickfree automatic Backup remove VCD
PostPosted: February 6th, 2012, 18:26
The VCD is not accessible via ordinary means. You need to disable it via an appropriate firmware update.
Otherwise here is a way to get rid of it completely:
disk-with-sata-usb-adapter-remove-virtual-rom-t18492-20.html
Your drive may be different, though.
PostPosted: February 6th, 2012, 18:40
My disk is a Clickfree.
Email support:
Hello
Thank you for contacting ClickFree support.
The CDFS partition cannot be removed from the Clickfree as the software resides on a chip inside the device and there is no way to format that partition.
We hope that we were able to assist you with your inquiry. If you are still experiencing any difficulties with your Clickfree device, please contact us again.
See the link below to take a look at the FAQs or full user manual for your ClickFree device.
Sincerely,
ClickFree Support
PostPosted: February 6th, 2012, 18:46
Why do you want to remove the VCD? Do you have some compatibility issue, eg with a TV or PVR?
PostPosted: February 6th, 2012, 19:19
Exactly, i need to use de hdd in a nintendo wii.
PostPosted: February 6th, 2012, 19:24
In that case all I can suggest is Gaucho's solution, assuming the internals are an OEM version of a WD SmartWare product:
PostPosted: February 20th, 2012, 5:03
Thanks tot Hayel2ko :cool: I've found a solution to this problem!!
http://windowssecrets.com/forums/showth ... post838182
I've tried it and it works great!!
I've used "Version 255.31.3.41.22", as on the site is says "Version 255.31.2.41.22". I've contacted Hayel and indeed it should be version 3 instead of 2. He's going to edit that on the site.
And at dot 5 there was some text before "JMS539" something like ..55.. before it.
After formatting the disk (on my iMac) for the full 1 TB the flashing light is still working... :( I hoped it would stop working as in the description.
So now I'm happy :yayaya:
PostPosted: February 20th, 2012, 11:17
I remove de disk from de the case, plug it into sata port, low level fotmat (hdd guru low level format), re-conect de disk in the original case... and its done!! the virtual CD dont exist more.
PostPosted: February 20th, 2012, 13:57
It took me no more than 5 minutes..... :)
PostPosted: February 20th, 2012, 14:05
This solution dont worked for me... My clickfree dont have the jmicron chip
PostPosted: February 21st, 2012, 10:23
Hayel has edit his posting and add this:
"For users that didn't get jms539 next to chip, you will have to open the external hard drive enclosure and find the sata controller chip, write down the model number and use that to find yourself a solution because you can't always depend on the internet on something like this. You have to start doing things by yourselfs and again not my responsibility if you screw up your external hard drive."
So perhaps you can do this?
Or what Villeda did
PostPosted: February 21st, 2012, 17:35
Which chip does it have?
Do you see any problems now that the VCD is gone? AISI, the bridge firmware will still be looking for the VCD "partition".
PostPosted: February 21st, 2012, 17:47
first of all, sorry for my bad English. Free translation made ​​by google:
The first thing was to try a low-level format the disk without removing the case, but this did not work.
I opened the case, remove the disk and plugged the sata port, from the Windows disk manager delete partitions and quick format. When you connect back to the case Clickfree reappear ntfs partition and the virtual CD. (you must highlight the fact that the data partition was 298 GB)
I removed the disc again the case, I connected to sata port, and this time I used HDD guru low level format tool, format the disk, create a single partition. Reconnected to the case Clickfree and this time the virtual CD is gone, windows recognize the disk, but asks me to initialize, create and format partitions using windows. (the new partition is 300GB)
Apparently the chip in the case can not format the disk boot sector, so that no elminate partitions, the low-level format from the port sata removes all traces of the two partitions.
Original en español:
Lo primero que intente fue hacer un formato a bajo nivel sin sacar el disco del case, pero esto no funcionó.
Abrí el case, quite el disco y lo conecté al puerto sata, desde el administrador de windows eliminé particiones y di formato rápido. Al conectar de nuevo al case clickfree aparecen de nuevo la partición ntfs y el CD virtual. (hay que resaltar el hecho que la partición de datos erá de 298 GB)
Removí de nuevo el disco del case, conecté al puerto sata, y esta vez usé HDD guru low level format tool, formatee el disco, cree una sola partición. Conecté de nuevo al case clickfree y está vez el CD virtual ha desaparecido, windows me reconoce el disco, pero me pide inicializarlo, cree las particiones y formatee usando windows.
Al parecer el chip del case no permite formatear el sector de arranque del disco, por lo que no se elminan las particiones, al dar formato de bajo nivel desde el puerto sata se elimina todo rastro de las dos particiones.
PostPosted: February 21st, 2012, 18:05
The chip: initio inic 1610l
Problems: not, yet
the bridge firmware will still be looking for the VCD "partition": No, I do not see the VCD partition in Disk Manager. And the new data partition now occupies all available space.
PostPosted: February 21st, 2012, 20:07
Thanks, that's good to know.
