 Post subject: WD My Book essentials + new clean hdd
PostPosted: May 8th, 2012, 8:48
Hi everyone,
I bought 3x WD My Book essentials 2Tb for £30 (minus the drives) - USB3 port only. They are in mint condition with the protective cellophane on, so it look likes they just needed the drives, everything else is there.
I will use one for DR stock & am thinking of using the other two with my spare WD 3Tb drives I have got.
I have managed to install the drives & format them through WD Smartware & that works great - Drive data is encrypted as expected via the bridge board. But when I use Smartware which is installed on my pc to password protect the drive - this works but the virtual cd it creates is 30mb & says raw. I can unlock it via the installed smartware but would like to recreate that virtual cd with the UDF & unlock applications ect to get it working properly? like it would be if bought new.
Any ideas?
Loki
 Post subject: Re: WD My Book essentials + new clean hdd
PostPosted: May 8th, 2012, 9:04
try to Update its FW see if it works or not 1st.
PostPosted: May 8th, 2012, 9:59
Just tried that, no joy.
Was thinking of trying a sector by sector clone of a working one? I'm assuming that the vritual cd sectors are actually stored on the hdd & not on a rom chip - otherwise the firmware should have worked?
Hmmmm a puzzle :D
PostPosted: May 8th, 2012, 10:01
yes you are right on hdd
do not forget the Master Key as well
PostPosted: May 11th, 2012, 5:54
Just to give an update.
Cloning a WD My Book Essential to a new/clean hard drive works fine & virtual cd also works.
I can now use it like a new one & saved me about £90 per device (£180 :D)
Just make sure you clone to same size drive.
Did my cloning using my DDI.
Loki
PostPosted: May 11th, 2012, 14:32
Doesn't matter. You can put VCD area just in every place near the end (correspondingly to its size) and strictly indicate the adress inside keysector.
Angel Data Recovery
Users browsing this forum: Hardcore Games and 11 guests
