 Post subject: remove screw with broken head from PCB board
PostPosted: October 11th, 2012, 4:18
how to remove screw with broken head from PCB board?
Any way to remove the damage screw?
 Post subject: Re: remove screw with broken head from PCB board
PostPosted: October 11th, 2012, 7:28
You could very carefully & accepting the risks use a drill to drill away & remove the damaged screw head.
Remove the PCB & then if your lucky use a pair of snipps on the shaft of the screw thats left to see if you can unscrew it.
Loki
PostPosted: October 11th, 2012, 9:12
Dremel time
PostPosted: October 11th, 2012, 9:15
I don't know what you have available to you in your area, but here is an actual screw extractor kit.
http://www.canadiantire.ca/AST/browse/6 ... ?locale=en
PostPosted: October 12th, 2012, 3:15
Hmm.. do you have one? Looking at the reviews, it doesn't sound very promising..
PostPosted: October 12th, 2012, 4:18
drc wrote:
Dremel time
Even better than hammer time :)
Data Recovery Cape Town
Users browsing this forum: No registered users and 98 guests
