 Post subject: suggest me some external HDDs which can be used as internal
PostPosted: October 15th, 2012, 17:22
friends I want to buy a new external hdd,I have decided WESTERN DIGITAL My Passport
Essential SE 1TB,but the reviews I heard are it cannot be connected as internal(by opening the case),is it true??
please suggest me some external HDDs which can be connected both externally and internally.....
they may be 1 tb or 2 tb
Thank you
 Post subject: Re: suggest me some external HDDs which can be used as inter
PostPosted: October 15th, 2012, 20:02
What is your goal?
Asking because why not buy an internal drive that you could use as internal and external?
PostPosted: October 16th, 2012, 3:36
labtech wrote:
What is your goal?
Good question :D
PostPosted: October 16th, 2012, 4:18
External HDDs are handy!!!
and that to their price is less,..
please help me out guys
PostPosted: October 16th, 2012, 4:53
I have bought several Ext WD's and removed the internal 3.5" SATA drive for use in a desktop. Most WD's internal USB to SATA board encrypts the drive so you can't go back and forth and you about destroy the case getting it out and void the warranty. The Seagates come out easier in my opinion no encryption. If your goal is to buy the ext drive to get the drive out for use inside a PC then your good to go with the larger external drives the small drives laptop size externals WD's have a unique USB only NOT sata connector on them so they do not work for internal sata connected drives. The seagates are still sata connectors at least the last 1TB I bought and removed was.
PostPosted: October 16th, 2012, 6:34
External drives are cheaper than internals?
PostPosted: October 16th, 2012, 6:47
Maybe where he is located they are ? I know when HDD's prices spiked last year for a short period externals were cheaper and all we could get our hands on at the time.
PostPosted: October 16th, 2012, 11:36
yep!
here 250 gb Seagate internal costs rs 3000 and 500 gb costs around rs 3900 whereas 1 tb external wb costs rs 4300,.....
PostPosted: October 16th, 2012, 11:38
yep!
PostPosted: October 16th, 2012, 11:43
If this was the OP's goal was to save money, then do not buy a WD 2.5" form factor as it is likely to be USB based interface drive. Also, same applies for the newer Samsung externals.
Alternatives? Seagate, Hitachi, Toshiba, etc.
PostPosted: October 16th, 2012, 14:26
How about Seagate GoFlex Ultra-portable
Drive 1 tb??
PostPosted: October 16th, 2012, 16:00
The ones I have opened have regular Sata Connections.
PostPosted: October 17th, 2012, 3:21
You mean all Seagate external (1tb,500gb,2tb) drives have sata connections and no problem when connected as internal???
PostPosted: October 17th, 2012, 4:01
Yes, to my experience all seagate externals could be connected internally with SATA with no problems.
Out of curiosity, you said:
How much does an internal 1TB cost then? Or an external 500GB? Because you're comparing different capacities.
PostPosted: October 17th, 2012, 4:18
500Gb external costs around rs 3000 whereas 1 Tb internal costs around rs 7000
PostPosted: October 17th, 2012, 4:26
Thanks for the info. That's very strange. It is the other way round, where I live.
Anyway, go for the Seagates then (dont use Blackarmours, they're encrypted) or Hitachi's.
Good luck.
PostPosted: October 17th, 2012, 6:09
Hitachi's are also same as Seagate???
PostPosted: October 17th, 2012, 6:12
Yes. Samsung 3.5" (but only 3.5") too.
PostPosted: October 17th, 2012, 6:22
what about Toshiba???
PostPosted: October 17th, 2012, 6:41
Atlast I found Seagate Expansion 1 TB
USB 3.0 + 2.0 Portable External
Hard Drive as Optimal
is this can be connected as internal??
Users browsing this forum: No registered users and 43 guests
