 Post subject: Ata password on Samsung 320gb hard disk
PostPosted: March 12th, 2013, 1:31
Hi every one
I have a samsung 320 Gb hardisk in dell inspiron 5010N. it got a password on bios and hdd. i manage to by pass the bios password but unable to bypass hdd password.I checked it on different system but it is locked. I also use MHDD it says the drive is locked by ata Password and security level is high.
Kindly help me if anyone can. Details are as follows.
ERROR CODE: RZB04697
Make: SAMSUNG
Capacity: 320 Gb
Serial No: S2ANJDRZB04697
P/N:HM320HJ/D
F/W 2AK10001
Model: HM320HHJ
Dell Service Tag: D0CK0N1
 Post subject: Re: Ata password on Samsung 320gb hard disk
PostPosted: March 12th, 2013, 2:13
You can take this to a DR company. Prove this is your HDD by showing proff of ownership and have the DR company unlock this one for you. You will not be able to do this one on your own and special tools will cost you around 10K that can handle this one. If this is actually your drive I would take it to a DR company. I think this one should not be too expensive for them to do this for you. You should get this done for less than 100 dollars I am sure of this. That is if there is no other problems on this drive and it is a password locked drive I believe this should be around the price a DR company will charge you for this one.
Iorana Haraharaini
PostPosted: March 13th, 2013, 1:30
And you can also try to go to the BIOS settings using the master password that i'm assuming you already have and turn of the hdd lock.
The master password id default Manufacturer set and i tried 32 times t but failed
You will also find on ebay a *huge* amount of sellers that generate those codes to unlock a dell locked hdd and sell them at the average price of $5 to $20.
I am from Pakistan and there is no ebay and Paypal service here
TRY password nnnnnnxs to unlock your HDD using the same dell that locked it.
its not working
Enter service tag, HDD serial number, or nothing at all: NJDRZB04697
NJDRZB04697 --> zb66tdse
MPWs calculated by newer BIOSes:
NJDRZB04697-D35B --> o1d5iev2
these two are also not working
PostPosted: March 13th, 2013, 6:40
Now you will use the keyboard arrow to navigate down to the available options and you will press enter, in this step a window
will pop up asking you for the current password, this is the BIOS master password. type it in and press enter again,
it prompts a system or disk password exists so you cannot set admin password.
And Admin Password and System Password status is NOT SET
rest of the things are not working
PostPosted: March 13th, 2013, 14:07
Ahmed where ru frm im also frm pakistan so tell where r u frm in the city so may be i can help u??
PostPosted: March 13th, 2013, 23:44
Spildit wrote:
ahmed22 wrote:
Hi every one
Make: SAMSUNG
Capacity: 320 Gb
P/N:HM320HJ/D
F/W 2AK10001
Model: HM320HHJ
Ok, i need some explanation here, otherwise i will not be able to assist any further .... IS THIS A STOLEN DRIVE/LAPTOP ?
Or did you get it from someone else ?
Can you explain why on this thread :
how-pass-bios-hard-disk-password-samsung-hdd-t25401.html
ANOTHER DIFERENT USER ( Aftab )
HAVE THE SAME HARDDISK THAT YOU ARE TRYING TO UNLOCK ?
Aftab wrote:
I have a dell inspiron 5010N Laptop. my child put a hard disk password on it and then forget the password. It has Samsung 320Gb hdd. Details of the hdd are:
Make: SAMSUNG
Capacity: 320 Gb
Model: HM320HHJ
I want to ask is there any way to get it functional although the data is not important
ThankYou
Guess that is why we say to take it to a DR company and prove that it is your drive. To unlock drives and give advise in such a case is not a good idea on this one. Do not know who the real owner of this drive actually is. Hard to prove it here on the forum too. At a DR company it is not hard to prove who the HDD belongs too. Nice advice
Iorana Haraharaini
PostPosted: March 14th, 2013, 0:43
I am from Islamabad
Yes u are right this is the same hdd. the other user is my friend to whom i asked help in this matter. we both are searching for the solution.
The hdd or Laptop is not a stolen one but actually it was a gift from my relative who is doing job in Saudi Arabia. I am not sure where he bought it from. I gave this to me in original Packing which I still have. Still if you want any proof i am willing to provide.
PostPosted: March 14th, 2013, 7:47
Spildit wrote:
Didin't the drive got that lock because of the other user son ? Now it was aquired already locked.... Then.... Someone alreay told a lie !
That is Also true it got a password by a kid but believe me it is not a stolen one. Kindly tell me how can i prove ownership to resolve this issue.
PostPosted: March 15th, 2013, 21:35
I tried a couple of that utility downloads but at extraction it give me error of corrupt file and then at dos prompts unable to run executable
PostPosted: March 16th, 2013, 10:40
Spildit wrote:
Rar file is damaged but files inside are ok.
You will need NATIVE DOS - run from dos boot disk. Command prompt under windows will not work.
I also download iso file and extract the utility and conf file but at native dos mode it gives error
Users browsing this forum: No registered users and 69 guests
