 Post subject: SFF-8784 edge connector
PostPosted: April 23rd, 2013, 8:17
I see some of these ultra thin drives are starting to ship with SFF-8784 edge connectors now. I haven't read through the spec, but I'm guessing we'll get an adapter for these soon?
ftp://ftp.seagate.com/sff/SFF-8000.TXT
ftp://ftp.seagate.com/sff/SFF-8252.PDF
Data Recovery Cape Town
 Post subject: Re: SFF-8784 edge connector
PostPosted: April 23rd, 2013, 9:07
The devices they seem to be targeting more are tablets and such.
WD is on pace with this as well:
http://inthenews.biz/2013/04/23/wd-ship ... -and-sshd/
But, why not, let's things more interesting!?!
PostPosted: April 23rd, 2013, 9:16
My post is under revision, but yeah, ultrabooks and such will use these as well.
*Will have lots of fun with forum questions regarding "why this is not my data?" when swapping PCBs on these suckers.
PostPosted: April 23rd, 2013, 12:01
Both the WD Blue and Black version of the ones you refer too are disk drives, one with NAND cache and the other without. My question was more wondering when (if) we'll see an adapter for SFF-8784 so that we can image them properly.
PostPosted: April 23rd, 2013, 12:12
I think it will depend on how popular they are in terms of failure. If failing a lot, we will have to come up with something.
PostPosted: June 19th, 2013, 7:08
SFF-8784 Specification for 0.8mm Card Edge Drive Connector:
ftp://ftp.seagate.com/sff/SFF-8784.PDF
SFF-8784 Edge Connector Pin Definitions Info Sheet:
http://www.wdc.com/wdproducts/library/S ... 771981.pdf
ISTM that it shouldn't be too hard to make your own adapter.
PostPosted: June 19th, 2013, 11:27
looks easy enough
...2 things about the receptacle...
1. For some reason the receptacle reminds me of the old floppy and HDD connectors, and
2. I've been spelling "Receptacle" (icle) wrong for years ;)
PostPosted: June 19th, 2013, 16:06
The connector has two rows of pins which are offset with respect to each other. Typical edge connectors do not have this offset.
