 Post subject: Cheap Desktop Cam guided SMD reworking
PostPosted: October 10th, 2019, 11:46
https://www.instagram.com/p/B3Z9yeEHcfE ... vy2xztf3jf
thanks
 Post subject: Re: Cheap Desktop Cam guided SMD reworking
PostPosted: October 13th, 2019, 13:00
Lol,
Might be you can explain it a bit to us Scientist sahib ? . To me a TSOP48 was placed under a CAM and you were mercilessly moving your solder up and down ,Let me teach you a trick ,There is something called drag soldering and there are drag soldering bits ,try that technique
PostPosted: October 14th, 2019, 11:25
Or just use a hot air rework and be done in 30 seconds. :wink:
PostPosted: October 14th, 2019, 16:08
Exactly...thats the way to go to....Honestly, I wanted to see some cross compatibility with other controllers and had some spare money to burn in the learning. So the exact purpose here is to connect my logic analyzer and have some fun for which I will have to connect very fine laminated copper wire (IFT / AM Coils used to have them, or the same one that you get with a JTAG finder device).
So just wanted to zoom in at 0 cost....btw this whole thing is under 5USD....works well for me atleast for these packages...
Sadly a few days ago my assistant plugged in a 12V supply into 5V input of the DeepSpar Stabilizer....it was a good timing that this happened a few days after I built the scope....Could figure out the problem myself and Serge really helped confirm and suggested what next was to be done....The unit is back to life.....
I am honestly speculating as a side kick project of using a cam and programming it using STM32 and displaying that on a relatively larger screen.....
PostPosted: October 14th, 2019, 17:42
Could we see photos of the innards?
PostPosted: October 15th, 2019, 4:49
I am sorry here. We are closely related to DeepSpar and can not do this. Not permitted.
if you see this http://www.deepspar.com/distributors.html , you can see Dr.Aroras company listed in the Indian division and one more company who is our dear friend in Gujrat,
sorry this time
