 Post subject: Super Gauntlet Hard Disk Test
PostPosted: August 6th, 2008, 4:33
Hi All,
I want to run some extreme tests on some of the latest hard disk generations :O)
Open for input into what set of tests to run!! The final test will be a drop test LMAO
At the end of it I will post the winners....
 Post subject: Re: Super Gauntlet Hard Disk Test
PostPosted: August 6th, 2008, 6:34
We had a laptop once that was run over by a lorry. Hard disk had a siezed motor. Also had a laptop that had been thrown against the wall, ths Toshiba HArd disk inside had shattered platters!
Would be nice to know what to expect from customer explanation of what happened!
We also had some hard drives that were in hurrucane Katrina, but the saltwater killed the disk and the platters were corroded. Would be nice to know how much salt water is enough to still secure recovery!
