 Post subject: Better/Stronger IDE cable connectors?
PostPosted: July 22nd, 2008, 16:30
Even though I seldom replace/install drives I have damaged my
share of IDE cables. When a cable is inserted into a drive or
mainboard connector sometimes there isn't enough of it exposed
to grab it with my fingers. I forget how weak they are and I wind
up pulling on the cable instead it just comes off the connector.
For those of you that do this every day - what's the trick?
What about your text/diagnostic hardware -- does it come
with more sturdy and better designed cable connectors?
 Post subject: Re: Better/Stronger IDE cable connectors?
PostPosted: July 23rd, 2008, 22:47
we all had this problem with ide cables breaking or coming away
i found out that since i switch over to round ide ribbon cable
they work great for data recovery
i dont have any problem anymore
its worth getting these cable they might be a little bit expensive around $15
but they work great and last a longtime
http://images.iocombo.com/thumb/product ... 293711.jpg
Users browsing this forum: No registered users and 291 guests
