 Post subject: RAID on two different drives
PostPosted: July 12th, 2008, 12:41
It is a weird question i think, but i think i should ask it :). Can i run RAID on two different drives ? I have one WD Caveir 60GB and a 160GB Seagate SATA. I know they are totally different in specs as well as capacity but i just want to test RAID and its benefits.
Thanks.
 Post subject: Re: RAID on two different drives
PostPosted: July 12th, 2008, 12:44
What benefits are you looking for?
PostPosted: July 12th, 2008, 15:32
Yes, you can build a 60GB RAID1, a 120GB RAID0, and 220GB LINEAR RAID and 120GB faulty RAID5 from this 2 drive.
On linux of course.... :D
Regards,
Janos
PostPosted: July 15th, 2008, 18:35
Just want to see performance boost.
and Janos do you mean its not possible on windows ? I use linux but only 10% (For university work :) ). Rest of the percentage is allocated to Windows :D
BTW Thanks for the replies.
PostPosted: July 16th, 2008, 16:06
I know, some of the raid is can be build on windows too, but the linux support is really flexible. ;)
