Tools for hard drive diagnostics, repair, and data recovery
Problems when installing Media Tools Proffesional - ERROR
September 22nd, 2010, 9:59
When trying to install I get error :
"Failed to communicate with CD-burning engine"
I have issues burning CDR discs, though DVDs work fine,.. this a known issue ive had for long though.. btw the driver is a NEC 3520-A
Re: Problems when installing Media Tools Proffesional - ERROR
September 22nd, 2010, 11:45
chk the following service working?
IMAPI CD-Burning COM Service
and did u try :
- another Blank CD Brand?
- update dvdrw FW try: http://forum.rpc1.org/portal.php
- try another recorder
September 22nd, 2010, 14:20
Einstain9, thx for the reply m8.
Ive just restarted the service and that did not work, yes it is running.
Another blank CD ive tried too (its not been working for quite some time I recall)
I just updated my FW with the same version I already had, the latest one from the official website.
Im trying to fix this recorder as I have no other at my disposal at this moment :=(
Any other ideas? :|
September 22nd, 2010, 15:05
wallstreet wrote:Any other ideas? :|
Write it to a floppy disk
September 22nd, 2010, 15:28
I dont have a floppy disk lol...
I tried burning again just to get the logfile from nero :
1C82-0000-19E5-MAAX-4001-4643-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <_NEC DVD_RW ND-3520AW> Version: 3.07 - HA 1 TA 0 - 7.10.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HGN J8HAFS5Q >Version: 1.03 - HA 1 TA 1 - 7.10.1.0
=== Scsi-Device-Map ===
DiskPeripheral : ST3320620AS atapi Port 1 ID 1 DMA: On
DiskPeripheral : WDC WD6400AAKS-00A7B2 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3520AW atapi Port 3 ID 0 DMA: On
CdRomPeripheral : HGN J8HAFS5Q 1.03 aetngl17 Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3520AW F: CdRom0
HGN J8HAFS5Q G: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 22 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.9.2010
CD-ROM (ISO)
8:54:23 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
8:54:23 PM #2 Text 0 File Isodoc.cpp, Line 6666
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:54:23 PM #3 Text 0 File Burncd.cpp, Line 3196
Buffer underrun protection activated
8:54:23 PM #4 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
8:54:23 PM #5 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using CD-R/RW media
8:54:24 PM #6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 88724 ( 19:44.74)
8:54:24 PM #7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
8:54:24 PM #8 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: _NEC DVD_RW ND-3520AW;
CDR code: 00 97 17 06; OSJ entry from: Moser Baer India Limited
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 11 06 (LI 97:17.06), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
8:54:24 PM #9 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
8:54:24 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 88725 (88725) = #88725/19:43.0
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 88725 blocks [F: _NEC DVD_RW ND-3520AW]
8:54:24 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [F: _NEC DVD_RW ND-3520AW] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 182016000, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 88725 | 0 | 0x00
88725 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
8:54:24 PM #12 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
8:54:24 PM #13 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
8:54:24 PM #14 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
8:54:24 PM #15 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
8:54:24 PM #16 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
8:54:24 PM #17 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 32x (4,800 KB/s)
8:54:24 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:54:24 PM #19 Text 0 File MMC.cpp, Line 17687
StartDAO : CD-Text - Off
8:54:24 PM #20 Text 0 File MMC.cpp, Line 22363
Set BUFE: Buffer underrun protection -> ON
8:54:24 PM #21 Text 0 File MMC.cpp, Line 17915
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 13 2d 00
8:54:24 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
8:54:33 PM #23 SPTI -1106 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x069d0ec0: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8:54:33 PM #24 CDR -1106 File Writer.cpp, Line 303
Power calibration error
8:54:34 PM #25 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 32x (4,800 KB/s)
8:54:34 PM #26 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
8:54:39 PM #27 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
8:54:39 PM #28 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
September 22nd, 2010, 17:30
I solved it, something wrong with my CD burner, I used my laptops CD burner.. ye dont ask ... what a moron I was ;)
