Tools for hard drive diagnostics, repair, and data recovery
after a lot of formats
November 24th, 2010, 1:36
is there a way to get lost files from the very first partitions..i tried a lot of programs like getdata back stellar foenix ..but didn't found them any suggestion?the files are audio projects from cool edit pro..thank you
Re: after a lot of formats
November 24th, 2010, 3:38
Try R-Studio..............
November 24th, 2010, 5:08
the topic says after allot of formats? So assuming you formatted the drive and used it for a while. or jsut full formatted it several times to try and destroy the data?If so its unlikely to get anything back.
November 24th, 2010, 11:53
yes i made some formats and used it for a while.i have used r-studio in the past i think so...i have found some files..butnot the whole porojects..i was watching some videos on security tube talking about reverse scanning..is there an aplication doing that for windows?i guess the only solution is hardware data recovery?
November 24th, 2010, 12:34
nespik wrote:yes i made some formats and used it for a while.i have used r-studio in the past i think so...i have found some files..butnot the whole porojects..i was watching some videos on security tube talking about reverse scanning..is there an aplication doing that for windows?i guess the only solution is hardware data recovery?
Hardware DR is not going to do this one for you. If you have formatted this drive X number of time and also used it for X number of days, months or so on then more than likely the data that was stored on this drive has been over written. If you can not find your data in raw recovery using R Studio, Get Data Back or Win Hex it more than likey is gone. You might be able to find some fragmented files left but not sure how good your changes on this one will be.
Sorry but that is how it works.
November 24th, 2010, 12:49
the most files i recover from r-studio won't work..wtf
November 24th, 2010, 12:53
Sorry- that is all you will get. Hardware recovery is used if drive is failing to hardware control certain things that rstudio or any other software cannot do.
November 25th, 2010, 0:50
You did not say what OS you used to do the format. If you did a full format using Windows Vista or Windows 7, your data is gone. Format was changed starting in Windows Vista. A full format wipes the whole disk with zeros.
See: http://support.microsoft.com/kb/941961
TonyC
