Tools for hard drive diagnostics, repair, and data recovery
December 10th, 2010, 11:48
I am new to all this - need some expert advice -here goes!
I have been trying to sort out my daughters slow laptop. To cut a long story short, I have tested the HDD using Everest Ultimate software and found that the Random Read Benchmark is coming out at 3.5MB/s. Is this good or bad? Shouldn't it be more like 100MB/s?? Also chkdsk is showing 32kb in bad sectors. ok I understand that the bad sectors indicates the disk has problems, but does this account for the low benchmark figure?
December 10th, 2010, 13:25
Yes, I'd say that the drive is starting to fail, which very likely could be causing the slow down. Backup the critical data immediately and replace the drive.
December 10th, 2010, 18:11
In addition to bad sectors, or as a consequence thereof, it could be that the drive is running in PIO mode.
Windows XP will downgrade a drive's performance from DMA mode to PIO mode if it detects more than 6 CRC errors.
DMA Mode for ATA/ATAPI Devices in Windows XP:
http://www.microsoft.com/whdc/device/st ... E-DMA.mspxDMA reverts to PIO:
http://winhlp.com/node/10Check Everest's SMART report. Otherwise here are two SMART diagnostic tools:
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/HDDScan for Windows:
http://hddscan.com/See this article for SMART info:
http://en.wikipedia.org/wiki/S.M.A.R.T.
I'd look for UDMA errors in the SMART report. These are said to be the result of cabling or communications issues.
December 10th, 2010, 18:14
Those drives are old and failure-prone. Get a new one.
December 10th, 2010, 18:42
These smart check/benchmark are quite useless... knowing the 6025 it may be degraded media or early symptoms of mechanical wear out. It is possible to squeeze out a bit of life from it bringing to 'like new' state but you would have to send it to me... Hence, get a new drive.
December 10th, 2010, 19:34
I got to bump fzabkars post. It is most probably the PIO mode issue.
I suggest download the Hirens boot cd - burn the disc (use another pc not the effected one or the burning will fail) - On boot press the button (F12 or F9) for "boot device menu" - Sometimes you have to go into bios and change first boot device to cdrom- and then later put it back (use "del") Boot the CD- Load the live Windows XP Mini mode and from the menu choose Testing > HDD Speed.
If the results are the same as in your normally installed windows. Then the HDD is kaputen. Copy all data asap- get a new.
If you are not comfortable with the BIOS i suggest not to mess to much in it. Ask a local IT techie to help you out.
Good Luck
December 11th, 2010, 8:19
Thanks guys for pointing me in the right direction. I am away for a few days, but will be back on the case later to follow up your suggestions. Will post back the results.
December 14th, 2010, 8:15
fzabkar,
Looking in device manager shows that the primary IDE current transfer mode is PIO. Tried setting it to DMA, as per microsoft link, but I cannot make any changes.
Reading the link, it says I need to uninstall/reinstall the primary IDE device, but I am nervous of trying this. I reasoned that if I uninstalled it, I would have a dead PC, with no going back since it is the C: drive!!
I have attached the full report from Everest which includes the SMART report
- Attachments
EverestReport.txt
- (296 KiB) Downloaded 1048 times
December 15th, 2010, 5:21
Yeah delete the Primary IDE and restart. After restart, the system will detect and install it again. Restart again and the system wil be in DMA mode automaticaly.
I have done that several times, no problem with it.
December 17th, 2010, 16:48
thanks for the info pclab
re-installed the primary IDE and have now got UDMA mode5. Everest Ultimate HDD benchmark now gives 20MB/s random read as opposed to my original 3.5MB/s. Cant be bad! I suppose all is well untill the next time it falls over!
December 18th, 2010, 1:16
Still, those drives are old and failure-prone. Be sure you have a good backup
December 18th, 2010, 15:36
These SMART attributes suggest that there may be a problem with bad sectors:
- Code:
05 Reallocated Sector Count 50 100 100 1 OK: Value is normal
C5 Current Pending Sector Count 0 100 100 12 OK: Always passes
December 18th, 2010, 15:50
I have saw this error quite often in new laptops with new HD's. It's a bug between the board and your OS, that automaticaly changes the speed of access.
But, having backups is always an excelent idea.
