 Post subject: How boot HDD LLF Low Level Format Tool from SD card
PostPosted: June 13th, 2012, 15:23
I need use HDD LLF Low Level Format Tool for the HDD with the s.o..
For this i need boot HDD LLF Low Level Format Tool from like a SD card.
Someone can tell me how i can boot HDD LLF Low Level Format Tool from a SD card?
Thanks !
Luciana
 Post subject: Re: How boot HDD LLF Low Level Format Tool from SD card
PostPosted: July 15th, 2012, 21:18
I tryed this way:
1) copy the folder HDDGURU LLF Tool to a SD card
2) boot MiniXP from Hiren’s BootCD 15.1
3) execute LLFTOOL from SD Card ( see point 1)
4) i select my HDD ( Fujitsu MJA2320BH G2) and I press the botton "Format this device"
5) this warning is displayed "Unable to lock device"
Someone can tell me how i can make LLF on one internal /empty/single HDD ??
Again thank !!!
Luciana
PostPosted: July 16th, 2012, 6:42
If your running Vista or Win7 why not just run a normal (not quick) format this way it will write zeros to the sectors.
You could also use diskpart & the clean all command on the correct drive from Vista or Win7. (both options can be run from the Vista or Win7 setup cd)
Or use a Ubuntu boot cd & then wipe/format the drive.
Secure Erase is another option
There are lots of ways to do this & google has the answers.
Loki
PS - Remember this is a data recovery forum & not a pc support forum :wink:
Users browsing this forum: No registered users and 121 guests
