Tools for hard drive diagnostics, repair, and data recovery
June 28th, 2013, 11:57
Hello Guys,
I have a USB 2.0 1Tb 2.5 Samsung HM100UX. There is something wrong with the usb connection. When I connect the usb cable the pcb does nothing, no lights. I was able to find a power point in the board like you can see in the pictures and I can power up the drive, light shows and motor spins. Tried to connect the usb cable at the same time but the drive spins for a minute and then stops.
I think the only solution is to convert it to sata connection. Can anyone tell me the sata connection locations?
http://gyazo.com/e64b6a82f8fa8a755524b519b7dfecc5http://gyazo.com/9bf9183243dc285630d8444da2fe2a97Thanks guys
June 29th, 2013, 3:35
FWIW, there was a fairly recent thread where the solution was to reflow a dry solder joint at a chip inductor near the USB connector. Might be worth a look ...
viewtopic.php?f=1&t=25581&p=174993The attachment shows the SATA Tx/Rx coupling capacitors ... I think.
- Attachments
- HM100UX_capacitors.jpg (52.99 KiB) Viewed 10329 times
November 25th, 2015, 14:05
