Tools for hard drive diagnostics, repair, and data recovery
December 17th, 2013, 5:42
Hi
This video is for running arco on mariner hdd with SEDIV.
regards
Waqas Ali
- Attachments
- manual arco.zip
- (3.03 MiB) Downloaded 1179 times
December 18th, 2013, 15:18
The aim of ARCO in this case should be changing drive format from 320GB/platter to 333GB/platter and obtainning a normal 500GB Mariner. You decided to keep the current format and reach only 480GB.
I didn't see in the video anything about the "selection portion of the field list". You don't know how to use it or the program doesn't have it?
December 19th, 2013, 4:34
no friend . see the video care fully . i edit flist in the video .
December 19th, 2013, 14:58
December 20th, 2013, 4:46
o OK . this is called factory info .
here u see TPI , capacity . max capacity , FMT capacity . sector density and many thing . and it is available after running arco . before arco all things are set to default .
December 20th, 2013, 13:48
waqas_ali766 wrote:o OK . this is called factory info .
No, it is called as I said and as is written on the picture.
It displays the setting for TPI, CAP, etc. one should make BEFORE running ARCO. Otherwize the default values are used and the ARCO typically ends with an error . That is why your videos show how drive starts ARCO, but never show how it completes successfully.
December 20th, 2013, 13:54
ok now i understand . u need second part of the video . in which arco complete correctly. tomorrow i upload it .
