 Post subject: utility to manually mark a bad sector
PostPosted: November 22nd, 2006, 19:14
do you know that such utikty does exist?
 Post subject:
PostPosted: November 23rd, 2006, 15:08
I know mhdd does perform the operation, but marking many bad sector is a long operation, and it is NOT performable via f.e. a batch file.....
 Post subject:
PostPosted: November 25th, 2006, 13:50
Victoria or Mhdd can remap erase llf bad sector good tool for badsector without fw problem .
 Post subject:
PostPosted: November 25th, 2006, 15:41
my problem is that I want to eliminate the red and brown block (weak sector), but even after a LLf, a remap with mhdd or Victoria, these weak sectors remain!!!
Problem is (i think) that my re-locate table is full.... smart tell me that i have raw sector 650!!!!! (max i remember had to be 50.......)
For this reason I have used makebad command by MHDD to transform these weak sector in really bad sector, so at least Windows mark they as defective and OS no longer get access to they....
But use makebad is a very long time operation: one sector per time......
 Post subject:
PostPosted: November 25th, 2006, 15:49
hi,
- try use vivard solution
http://www.copyrsoft.com/en/products/02/
 Post subject:
PostPosted: November 25th, 2006, 16:16
Thanks bubu321,
but the utility I'm searchin for have to let me the possibility in marking as bad sector the sector number i want!!!
In other way: an utility who is able in transforming f.e. a good sector in a bad sector.
 Post subject:
PostPosted: November 26th, 2006, 7:12
The Last hope for u is pc3000 clear glist function and use logical scanning by using functions add defect to plist .
 Post subject:
PostPosted: November 26th, 2006, 9:53
I understand, but if hd have so many defect that the p/g list may not cover all, the only way i think is manually mark ad UNC these weak sector, so formatting under windows, will let that OS no longer have access to it.
My hd is so damage that you may think to it as a very old hd when no defect re-allocation table exist......... ;-)
BTW with the procedure i described: mark with mhdd -->makebad command, now (even if chkdsk tell me I have bad sector) hd works very well with no slowdown at all.
For this reason I'm searchin an utility able in manually generate UNC sectors......
Thanks to all!!!
 Post subject: Bad sectors
PostPosted: December 3rd, 2006, 12:00
I made some resaearch and I found a website who has a lot of helpful link like manufacturers website..you can find there software to repir your hard disk bad sectors. <removed, spam site> Good luck.
 Post subject: Re: Bad sectors
PostPosted: December 3rd, 2006, 13:52
You were so kind, but what I need is an utility able in generate bad sectors, not repairing them.....
Bye
 Post subject:
PostPosted: December 14th, 2006, 16:51
the utility is on the way, in a few day will be ready for beta testers, but where may I post it?
Are there any volentereus beta tester for it?
 Post subject:
PostPosted: December 14th, 2006, 23:01
danrevella
You are welcome to upload it somewhere here: http://files.hddguru.com/index.php
After you upload it, please send me a PM and I will approve the file.
 Post subject: Re: utility to manually mark a bad sector
PostPosted: June 26th, 2014, 12:16
so what about the utility?
PostPosted: June 26th, 2014, 12:32
My utility is here:
http://files.hddguru.com/download/Software/Makebad/
PostPosted: June 26th, 2014, 13:12
O, thank you!
The problem is that I have a sector, attept to write to which hungs the HDD forever (until shutdown). So I does not need to scan the disk - just mark. Looikng into readme and faq, I still have no idea - could your program just mark BB without previous scanning?
I usually use Victoria, lot less experienced with MHDD.
PostPosted: June 26th, 2014, 19:12
I suspect that MakeBad makes use of the ATA Write Uncorrectable command to flag a sector as "pseudo-uncorrectable". CHKDSK would then add this sector to the $BadClus metafile.
Users browsing this forum: Google [Bot] and 40 guests
