 Post subject: Sediv 3.9.6
PostPosted: December 13th, 2013, 11:45
Hello every one ,
here is a new software for repairing W.D hard disk in advanced level .
this software has a lot of function.
Main features of the full version:
1) Read / Write module (optional).
2) Read / Write Track (optional).
3) Read / Write Flash.
4) Edit head map in Flash.
5) Work with defects.
6) Work with the translator.
7) Turn off the heads (Flash, command).
8) Other useful stuff (some open, some still in the process).
9) Work with SMART
10) Self Scan (editing the script, launch, track the status).
11) Self Scan SA.
12) Format SA.
13) Adding ARCO tests.
14) Running ARCO tests (all supported drives ROYL, including the 2013 release).
15) Running DVT tests.
16) Run Tests Servo Calibrate.
17) Power Management PC3000.
18. Test CHS before running ARCO. to check heads and zones either they are good or bad .
19. Unlock selfscan and arco on latest Hdd .
20. Support latest hdd arco in which c8 and c3 is not available, like trials , trexs, and daible hdd.
21. Support all kind of arco
22. have option to write tracks and if found bad track you will add it to SA list manually .
There are no any other tools in market which supports these functions .
here is the link of trial version and videos .
http://sediv2008.narod.ru/DEMO3.91Passw ... 567890.rar
Links for videos
http://sediv2008.narod.ru/0.exe
http://sediv2008.narod.ru/1.exe
http://sediv2008.narod.ru/2.exe
http://sediv2008.narod.ru/3.exe
http://sediv2008.narod.ru/4.exe
http://sediv2008.narod.ru/5.exe
http://sediv2008.narod.ru/DF3.exe
http://sediv2008.narod.ru/DF3-New.exe
http://sediv2008.narod.ru/ARCO_NEW_Denali.exe
http://sediv2008.narod.ru/BadHeadCut.exe
http://sediv2008.narod.ru/DisableBadHead.exe
http://sediv2008.narod.ru/ChangeHdMapInRAM.exe
If any one intent to buy, contact me at:
waqasali766@hotmail.com
0092-51-4452843
0092-346-5149378
 Post subject: Re: Sediv 3.9.6
PostPosted: December 13th, 2013, 12:32
Eset antivirus identifies this as a trojan:
Win32.Packed.Themida.AAF is a kind of Trojan that secretly enters into the system and performs malicious activities thereon. There are many methods by which it can reach your PC including network connection, file sharing site, unforeseen link or even by an instant messenger application. So, be cautious while carrying out any activities on your system as this Trojan can activate itself without making any information to the users.
I think before anyone buys or even tests demo you need to reassure that it is not malicious...
PostPosted: December 13th, 2013, 14:00
it was not a virus , if your antivirus tell that it was a torjan then there is a bug in antivirus . use Avira antivirus , its worlds best antivirus.
PostPosted: December 13th, 2013, 15:02
If you upload the RAR to VirusTotal, you will probably find that several AV software detects it as being infected.
http://www.virustotal.com/
I contacted SeDiv's author in the past and IIUC he explained that he incorporates code-morphing components to defeat reverse engineering. This is what triggers the "heuristic" warnings in certain AV products. Personally, I trust Kaspersky more than the others, and AFAIR Kaspersky gives SeDiv the all clear.
That said, I don't understand why anyone would package a video in an EXE. That in itself would concern me.
PostPosted: December 14th, 2013, 3:53
yes i am selling sediv full version , with sediv author permission .
latest version is 3.9.7
also i am giving technical support for sediv users.
PostPosted: December 15th, 2013, 4:51
I don't know why either, but Ace Laboratory and Salvation Data do as well, macromedia Flash animations are the majority. Soft Center provides animated animated gifs and are faster and smaller than .exes with less security risk.
PostPosted: January 29th, 2014, 9:43
so this software with new discs will not work. sense of what's in it?
WDmarvel
PostPosted: April 22nd, 2014, 21:33
how is the price???
PostPosted: April 23rd, 2014, 11:47
tutuyale wrote:
how is the price???
You can email the guy and find out, link is above
PostPosted: March 9th, 2015, 13:42
What do you mean by "DVT tests"?
Is there any manual coming with this software?
