 Post subject: MHDD, STI-2 and 2TB+
PostPosted: April 10th, 2016, 16:53
Hi, all!
When I check 3TB HDD Seagate over IDE-SATA controller STI-2 (Agestar), my HDD disconnected.
When the HDD about 80GB -- check all right.
Why? May be need any DOS-driver?
On another PC (with SATA) MHDD check pass normally.
 Post subject: Re: MHDD, STI-2 and 2TB+
PostPosted: April 10th, 2016, 18:05
If you are connecting a SATA drive to an IDE port via a SATA-IDE bridge, then you shouldn't need a driver. The SATA HDD should just appear as a PATA drive to BIOS and OS.
Could it be that your bridge PCB cannot handle 6Gbps link speeds? Can you identify the bridge IC? Perhaps its datasheet will provide a clue.
Is this your device?
http://www.agestar.com/en/Products/conv ... board.html
Product Specification
Material
wood <---- maybe this is the problem :-)
Date transfer rate
66/100/133MB/s
Output interface
40 pin IDE
Suitability
3.5in SATA HDD
Operation system
Windows 98se/Me/2000/XP/Vista
http://www.agestar.com/components/com_v ... 778db5.jpg
http://www.agestar.com/components/com_v ... ee2625.jpg
http://www.agestar.com/components/com_v ... ce4962.jpg
PostPosted: April 10th, 2016, 18:23
I notice that the PCB can be jumpered for either Device 0 or Device 1. I presume this corresponds to IDE Master and Slave, respectively. The default jumper position selects Device 1. Wouldn't it be advisable to select Device 0 (Master)?
PostPosted: April 11th, 2016, 19:39
Yes, it's the same device. But as I tested it, it stopped working altogether. Total 4-5 times included.
some shit
PostPosted: April 12th, 2016, 18:30
It may be that the device is broken?
PostPosted: April 12th, 2016, 19:15
I would test the adapter with a 1.5Gbps HDD, if possible.
Is the bridge IC a JM20330?
http://beyondwind.duckdns.org/wp-upload ... v.-2.3.pdf
PostPosted: April 13th, 2016, 8:20
Convert card full name:
STI-2 (AS-IS-20330)
http://www.agestar.com/en/Products/Conv ... board.html
If card is broken it possible to remount it?
Today I attempt switch her in another PC.
PostPosted: April 13th, 2016, 16:13
I see that people have a lot of problems with IDE-SATA adapters in the user forums. They seem to be a hit-and-miss affair. The "20330" in the name would suggest that the bridge is indeed a JMicron JM20330. It's datasheet says it is a 1.5Gbps device. Perhaps it is unable to negotiate a SATA link with current 6Gbps HDDs? Otherwise I have no idea what could be wrong. Sorry.
PostPosted: April 14th, 2016, 19:12
"It's datasheet says it is a 1.5Gbps device"
Thank you. I understood.
I thought, can reduce Gbps HDD by jumpers.
