Tools for hard drive diagnostics, repair, and data recovery
Great hardware and professional data recovery software
June 14th, 2016, 8:41
Hello
1) I want to know what are the professional products for data recovery? both hardware and software.
2) I want a program that can repair damaged files of any file if you can.
3) it would also like the software would be able to recover the in-depth level data that is able to recover data encrypted and will be able to recover the hard disk encrypted etc ....
4) So I need some sites or shops where they also sell these products Italian suppliers.
Thanks I await your answers, please answer the following questions.
Re: Great hardware and professional data recovery software
June 14th, 2016, 9:53
Answers:
1) There's a dozen other threads on this forum where this is discussed, try searching
2) No program can repair "any file". You'll need dozens of different programs for different purposes
3) Unless you expect you'll always know the encryption keys, there's no software for this either. Encryption breaking requires specialized hardware which will cost you a small fortune.
4) Almost any data recovery software or hardware company will sell internationally, so it doesn't matter where you're from.
I'm not trying to come down on your questions, I'm really not. But the first thing you'll need is knowledge of data recovery. Without such knowledge, all the equipment and software in the world will be useless to you. For example it's a typical amateur mistake to go looking for file repair software for corrupt files after recovery, when 90% of the time they are corrupt because the entirely wrong data was "recovered". I've talked with guys online who've spend hundreds of dollars on such software, when a professional could have taken one look in hex and determined that the data in the file they're trying to repair isn't even the right type of file.
Your questions sound like you want a push button solution, when no such solution can, or ever will, exist.
July 20th, 2016, 0:16
Hello, I agree with what data-medics says, and I am not offensive either, but in DR field, some corresponding knowledge is really needed, there is no program that can repair damaged files of any file actually;
And for your third question, I think MRT tools could be a helper, but it can not decrypt all the models now; sometimes the encryption keys are indeed very important if you want to get the data back;
And for your last question, MRT products have two different versions--- Chinese version and the international version( English version), so if you can understand English, you can choose the international version.
What's more, in DR field, sometimes you do not need to recover data, you'll just need to repair/refurbish the disk, like shielding the bad heads, bad sectors; and MRT can even sheild the head of Seagate F3 disks, which is the leading technology in DR field, here is a link for your information: viewtopic.php?f=28&t=33791 or you can go to our website for more information: http://en.mrtlab.com/
