Tools for hard drive diagnostics, repair, and data recovery
Issue to merge 2 partition
December 30th, 2016, 5:16
Hello
I cloned an SSD Samsung EVO 850 - 250G to a larger 500G
On the 250G, I had :
- OS boot partition of 217G (C:)
- Recovery partition of 20G (created by windows 10)
Now when I clone it on the 500G, I get (see attachment)
- Free partition of 227G that I formatted (D:)
Now I would like to extend C: with the space of D: to get a single big partition C:
With the partition tools that I try (paragon, easus), I can't because of the 20G partition in the middle....
Any idea ?
Thanks for help
Re: Issue to merge 2 partition
January 3rd, 2017, 17:43
You can delete your "D" partition, move the 20GB one to the end of the drive, then expand the "C" partition.
But maybe then the recovery partition will not work anymore as intended. If you decide you don´t need it, you can also delete them both and resize the C partition to occupy the whole space.
January 4th, 2017, 0:11
Hello
yes...thats the point if i move the recovery partition it will not work anymore and i need it.
maybe my question is more "how to move win10 recovery partition"
as i see a few tuto for that on google, i suggest that the moderator close this topic
January 4th, 2017, 15:58
Use Gparted. Its free!
http://gparted.org/
You can move the partitions one at a time. Then resize the "C" partition using the empty space.
