 Post subject: How can I power this HDD?
PostPosted: June 15th, 2019, 8:28
How can I power this HDD i've linked an image. I have a usb to sata connetion which works for all my other HDD/SSD but this one has another thing required? Not sure what it needs. From looking at the picture can anyone tell? many thanks!
File comment: HDD, with sata connection plugged in. some other connection on the left there? not sure what it is?
 Post subject: Re: How can I power this HDD?
PostPosted: June 15th, 2019, 10:39
Two screws are missing.
PostPosted: June 15th, 2019, 10:48
I realise, I'm certain that's not the issue (theres another identical one with the screws in that also behaves the same). I believe this needs to be powered other than USB alone and Im trying to find out what cable is required
PostPosted: June 15th, 2019, 11:03
3.5" drives use both 5V and 12V, whereas 2.5" drives use only 5V. USB provides only 5V, so you can power up only 2.5" drives without external power supply (12V).
PostPosted: June 15th, 2019, 11:27
Great thanks, So it looks like I need a 12v for my 3.5" HDD here, is that just a sata that can plug into a wall?
PostPosted: June 15th, 2019, 11:30
something like this perhaps? https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Users browsing this forum: No registered users and 28 guests
