 Post subject: Block size in hdd raw copy tool
PostPosted: July 2nd, 2020, 6:22
What is the block size hdd raw copy tool uses?
I'm copying a near-death drive and the tool told me about some read errors (mentioning the offset and the LBA, semaphore timeout had expired).
Does it mean that a single sector wasn't copied, or something bigger (512,4k or any other block size used internally in the tool)?
 Post subject: Re: Block size in hdd raw copy tool
PostPosted: July 3rd, 2020, 2:39
Not recommended to use hdd raw tool on damaged drive with bad sectors or weak/bad heads.
For free tools, would recommend hddsuperclone or ddrescue.
