Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: New DeepSpar USB Stabilizer
PostPosted: October 10th, 2020, 16:41
Depends how you read that line .. ;)
With basic adapters it can be used with almost any type of storage device, including SATA drives and the newest AHCI/NVMe PCIe SSDs.
PostPosted: October 10th, 2020, 17:50
I'm still curious as to why one would need Win 10 x64. Does the stabilizer call home to Deepspar every time you use it? If it enumerates as a standard USB mass storage device, then I should be able to use it on an old DOS machine with UASP drivers. So what gives?
PostPosted: October 10th, 2020, 18:10
Because it comes with 64 bit software perhaps?
I haven't checked but it works fine without internet access.
Out of the box it presents itself as a small drive, maybe you could get this far in DOS, I dunno. You need to install driver to get the system to see drives you plug into the stabilizer. You control settings using 64 bit software.
PostPosted: October 10th, 2020, 18:17
Maybe this is one of those devices that needs its firmware ("driver") to be downloaded via USB every time it starts up? Cypress has an EZ-USB product that works this way.
Users browsing this forum: No registered users and 107 guests
