June 8th, 2024, 7:51
June 8th, 2024, 8:07
June 8th, 2024, 13:32
June 8th, 2024, 20:54
pepe wrote:i guess no special hw is required, the process depends on the nature and extent of the corruption. It is gonna be though if you have no insight. If it is simple VHD, the task reduces to a logical recovery, if it is VHDX or has snapshots, you will get some difficulties.
June 8th, 2024, 20:57
fzabkar wrote:Can you start by opening the VHD in DMDE and showing us DMDE's Partitions tab?
https://dmde.com/
Is 7Zip able to open the VHD?
June 9th, 2024, 2:31
MISU wrote:I have got a VHD repair job ,affected file is not getting mounted & is 1TB in size ,extracted data might be extremely large. If file can be repaired without extraction that will be best option ( must get mounted again)
I haven't done such enormous work before & don't know what kind of computing power ,memory & software needed .
Can someone guide me whether its possible on normal desktop level or need highly advanced setup.
Thank you
June 9th, 2024, 13:26
einstein9 wrote:MISU wrote:I have got a VHD repair job ,affected file is not getting mounted & is 1TB in size ,extracted data might be extremely large. If file can be repaired without extraction that will be best option ( must get mounted again)
Thank you
What is the OS of the VHD?
June 10th, 2024, 1:42
MISU wrote:einstein9 wrote:MISU wrote:I have got a VHD repair job ,affected file is not getting mounted & is 1TB in size ,extracted data might be extremely large. If file can be repaired without extraction that will be best option ( must get mounted again)
Thank you
Thanks einstein9
This VHD is on Hyper-V of windows 2012 R2.(Raid 5 server)
June 10th, 2024, 6:43
einstein9 wrote:MISU wrote:einstein9 wrote:MISU wrote:I have got a VHD repair job ,affected file is not getting mounted & is 1TB in size ,extracted data might be extremely large. If file can be repaired without extraction that will be best option ( must get mounted again)
Thank you
Thanks einstein9
Win 2012 easier to fix - chk ur PM
