Tools for hard drive diagnostics, repair, and data recovery
April 26th, 2007, 17:14
where is the manual
April 27th, 2007, 7:56
rameez wrote:where is the manual
Here it goes
Doomer wrote:Anyway, you could change capacity with Mode Select command, try to find program for sending SCSI commands (For example, Bus Hound can send SCSI-command to a SCSI-drive, I beleive there are many other programs)
Read SCSI-standard (from t10.org) for Mode Select and Mode Sense command and do this
After changing capacity you should start SCSI format (every SCSI controller with BIOS can do this)
