Tools for hard drive diagnostics, repair, and data recovery
HDD Scan question
January 3rd, 2008, 7:37
I have been trying out HDD Scan v2.8, which seems to be a good program. However the docs that downloaded with the program are unreadable, as in example ÈÍÒÅÐÔÅÉÑ
1. çàäåðæêè ïîäîáðàíû èñõîäÿ èç ðàçìåðà áëîêà äëÿ òåñòèðîâàíèÿ â 256-òü ñåêòîðîâ
2. âåðèôèêàöèÿ ìîæåò íå èäòè ñ áëîêîì äëÿ òåñòèðîâàíèÿ áîëüøå 256-òè, ýòî îãðàíè÷åíèå Windows
3. äëÿ USB-äåâàéñîâ ôóíêöèÿ Verify îáû÷íî ðàáîòàåò íåïðàâèëüíî
How can i get readable docs for this software.
Re: HDD Scan question
January 3rd, 2008, 12:28
Doc has been written in Russian
This is the reason why you cannot read it
Unfortunately English doc is not exist
In HDDScan3.0 English doc will be included (probably :) )
January 3rd, 2008, 13:11
I appreciate you reply. Thanks
March 23rd, 2008, 15:52
It is possible to know the difference between the "Verify" and "Read" commands. Also, when the Erase command is selected, are all sectors between the Start LBA and End LBA erased or only those whose read delay is over a certain amount (500ms ?).
Thanks.
March 26th, 2008, 8:57
MerleOne wrote:Hi,
Verify mode is using read verify command
Read mode is using Read command
MerleOne wrote:Also, when the Erase command is selected, are all sectors between the Start LBA and End LBA erased or only those whose read delay is over a certain amount (500ms ?).
March 26th, 2008, 9:07
Doomer wrote:
MerleOne wrote:Hi,
Thanks, especially for the erase command !
.merle1.
