 Post subject: HDDScan S.M.A.R.T. Report
PostPosted: December 4th, 2009, 9:37
Can anybody help me out,pls see the report and tell me the status of my hardisk.
ThankYou
Model: SAMSUNG SP0802N
Firmware: TK200-04
Serial: S00JJ40X325899
LBA: 156365903
Report By: HDDScan for Windows version 3.2
Report Date: 12/4/2009 6:54:38 PM
Num Attribute Name Value Worst Raw(hex) Threshold
001 Raw Read Error Rate 001 001 00000000-34E8 051
003 Spin Up Time 100 100 00000000-1080 025
004 Start/Stop Count 100 100 00000000-0229 000
005 Reallocation Sector Count 016 001 00000000-00B6 011
007 Seek Error Rate 100 100 00000000-0000 051
008 Seek time Perfomance 100 100 00000000-0000 015
009 PowerOn Hours Count 100 100 00000002-ABCA 000
010 Spin Retry Count 100 100 00000000-0000 051
011 Recalibration Retries 100 100 00000000-0095 000
012 Device Power Cycle Count 100 100 00000000-0133 000
194 HDA Temperature 109 097 43 C 000
195 Hardware ECC Recovered 100 100 00000013-9962 000
196 Reallocation Event Count 001 001 00000000-4072 000
197 Current Pending Sector Count 100 100 00000000-0000 000
198 Uncorrectable Sector Count 001 001 00000000-4072 000
199 UltraDMA CRC Errors 200 200 00000000-000D 000
200 Write Error Rate 100 100 00000000-0000 051
201 Soft Read Error Rate 100 100 00000000-0000 051
 Post subject: Re: HDDScan S.M.A.R.T. Report
PostPosted: December 4th, 2009, 11:32
Your drive has remaps and lots of bad blocks
Backup your data and dispose the drive
PostPosted: January 3rd, 2010, 7:29
I have a very similar problem with my Samsung SP0802N. But I can't even take an image of it...all software I tried refuse even to initialise the drive :? ...if I want to access the drive it clicks a lot..
But if I start in Windows, one of three partitions (the manufactor's backup's partition) is still accessible...
Can anyone give me a tip how I could rescue at least some of the data on it?
Thx a lot in advance!
So long
p@sco
PostPosted: January 3rd, 2010, 8:38
Your H1 is dead in the drive.
You have no chance to get the data from H0 without special equipment.
If your data is important, seek for professional help.
If not, drop the drive away and live without your old data.
If you force the drive for spin, you will get the condition more worse, and your drive are close allready to the unrecoverable state.
Janos
PostPosted: January 13th, 2010, 5:00
How much costs professional help for this drive?
PostPosted: January 20th, 2010, 11:04
im having a different Error shown by the S.M.A.R.T report.
Model: MAXTOR STM3160215AS
Firmware: 4.AAB
Serial: 6RA7A2LN
LBA: 312581808
(2MB cache)
001 Raw Read Error Rate 100 253 00000000-0000 006
003 Spin Up Time 097 097 00000000-0000 000
004 Start/Stop Count 096 096 00000000-136A 020
005 Reallocation Sector Count 100 100 00000000-0000 036
007 Seek Error Rate 084 060 00000FE2-D208 030
009 PowerOn Hours Count 094 094 00000000-16F0 000
010 Spin Retry Count 100 100 00000000-0000 097
012 Device Power Cycle Count 096 096 00000000-1366 020
187 Reported Uncorrectable Error 100 100 00000000-0000 000
189 High Fly Writes 100 100 00000000-0000 000
190 Airflow Temperature 065 052 35 C 045
194 HDA Temperature 035 048 35 C 000
195 Hardware ECC Recovered 070 062 00000000-452B 000
198 Uncorrectable Sector Count 100 100 00000000-0000 000
199 UltraDMA CRC Error Count 200 200 00000000-0001 000
200 Write Error Rate 100 253 00000000-0000 000
202 Data Address Mark Errors 100 253 00000000-0000 000
im not sure whether this "UltraDMA CRC Error" is the main cause of Very Slow file Copy speed in windows 7. Copy starts at 40-50MB/sec then falls back to 20-15mb/sec. :(
c: 26.3 free space 4.17GB
D:122 free space18.5GB
I have already switched the sata cable from my DVD burner but that didn't help.
So if this error is from faulty cable ....then replacing the cable SHOULD put the "UltraDMA CRC Error Count" to 0 ......????? do i sound right?
eagerly waiting for your response.
PostPosted: January 21st, 2010, 12:45
can any one help???? :?
PostPosted: January 21st, 2010, 13:27
http://www.google.com/search?hl=en&&q=w ... =&aqi=&oq=
PostPosted: January 21st, 2010, 18:21
i do know that most of the time UltraDMA CRC Error Count is due to faulty cable....but i have already changed the cable yet
the value still shows 1. So this means the problem is still there????
PostPosted: January 21st, 2010, 23:29
No
