Post new topic Reply to topic  [ 206 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: New version of UFS Explorer
PostPosted: July 12th, 2022, 2:03
What's new in version 9.9:
* Added 'activity monitor' tool to display the activity of the software instance with disks;
iSCSI support:
- Initiator (client) now doesn't require multi-host/cluster mode and works on single connection;
- The Target (server): fixed several network communication issues;
* Microsoft Storage Pools (Storage Spaces):
- Added support of 'Parity of mirrors' internal configurations;
- Added support of 'Three-way mirror' configurations (when the number of components is a multiple of three);
- Basic support of so-called 'dual parity' on Windows Server 2012R2 (also with adaptive reconstruction with single missing);
- Fixed bug with 'Two-way mirror' (in span, not rotation mode), created on Windows Server 2016 and later;
* When image file has associated map of defects, added automatic recognition of presence of that map:
- Software asks to load associated 'Attr.map' for 'TaskImage.bin' when it is present in the same folder;
- Added support of saving of map association to image files in VHDX format and software asks to load the map if the file is found;
* Software now uses 'storage with map' icon for 'defects recognition' and SDLSP with enabled internal map of block states;
* Linux software version:
- Added support of indication of OwnerID/GroupID for Btrfs, EXT2-4, UFS1-2, XFS and ZFS;
- OwnerID/GroupID is also preserved for scan results of these file systems;
- OwnerID/GroupID can also be preserved when data is copied (when copying of 'standard' attributes is enabled);
- Fixed one scenario of GUI-related crash bug;
* Fixed few bugs related to XFS file system scan;
* Updated HFS+ scan procedure to support file system recovery when main metadata locations are wiped;
* Updated Btrfs file system scan procedure for finding fragments of very fragmented deleted files;
* Fixed issues with support of text LVM configurations created by CentOS 8.
PostPosted: September 21st, 2022, 10:49
What's new in version 9.10:
* Added a tool to open Microsoft Storage Space volumes manually (to select metadata source and volume);
* Assembled Storage Space volumes now provide sector map information (allocation and defects, if available);
* Reworked RAID1E module: added support of multiple missing drives and optimized data access procedure;
* Rework to Microsoft Storage Spaces module:
- Reworked procedure of automatic assembly of volumes to use only the latest version of metadata;
- Automatic assembly of volumes is now made optional (it can be disabled in the settings);
* Scan result (VRFS) now also can be saved from context menu of the root folder of a scan result;
* Added support of map files (log files) created by GNU ddrescue;
* Using of maps of defect blocks:
- Support of maps after storage transformation/remapping (e.g. for BitLocker encrypted volumes);
- Indication of defects on assembled RAID1E when pair of components missing or contain map of defects;
- Software-generated defects now do not interrupt quickly the partition detection procedure;
* Update to ReFS3 scan: fixed a couple of bugs in the scan completion procedure;
* Update to FAT32 scan: better file system recovery when superblocks are lost AND FAT tables are damaged;
* Simplification to disk imager: single 'location' for metadata and automatic creation of log/map files;
* BitLocker decryption now supports multiple recovery keys (when available) for the same volume;
* For BitLocker-encrypted volumes, partition properties panel now displays properties of encryption.
PostPosted: October 25th, 2022, 13:46
What's new in version 9.11:
* Added possibility to import existing (completed or 'in progress') images to 'imaging tasks' of UFS Explorer;
* Minor re-arrangements to 'imaging task' UI;
* In the Manager of Storage Spaces: the display of the list of participating disks has been added (from loaded metadata);
* Tool for applying 'delta' was modified to:
- Exclude storages with capacities that don't match to delta file;
- Select the last component with the matching ID (if available);
- Remove this option from context menu of base (not differencing) VHDX;
* In disk imager:
- Target write speed (in MB/sec) is replaced with more informative indication (Slow/Normal/Good), relative to the overall copying process;
- Replaced window for 'disk lost' notification with automatic 'yes' response to 'retry' request after 60 seconds of inactivity;
- Fixed bug in handling of SDMF map tail;
* In LVM manager: when there is a problem opening thin LVM volume, added detailed error message with indication of problem on the metadata area;
* Few fixes and minor update to 'search partitions' dialog;
* Added indication of encryption information for APFS encrypted volumes and LUKS;
- This indicator now also can be used to start decryption dialog;
* Storage ID for VHD and VHDX now contains their GUID value (Write GUID for VHDX);
* Added indication of parent virtual disk for delta-file of VMDK, AVHD and AVHDX formats:
- All formats include indication of the 'parent path' hint;
- Microsoft AHDX and AVHDX files also indicate GUID of parent virtual disk.
PostPosted: December 7th, 2022, 15:39
What's new in version 9.12:
* TrueCrypt/VeraCrypt:
- Added support of 'chained' encryptions (such as AES over TwoFish etc.);
- Added support of VeraCrypt PIM (non-system volumes);
* Reworked dynamic HTML report to different data model: this allows to open it much faster and to support hard links;
* In the 'Open thin-provisioned LVM volume' tool:
- Opening of volumes with damaged metadata is now made optional (it is possible to cancel it after notification about an error);
- Added the dialog window to display error location (with possibility to copy the offset) and with the option to open error location in hexadecimal viewer;
- Sub-partitions or encryption on the start of LVM data volume now don't mask it from detection by this tool;
* Activation of a LUKS-encrypted partition now activates the decryption procedure;
* Default 'activate' action for a BitLocker partition is now changed to 'decrypt' with automatic opening of the decrypted partition (on success);
* List of file copying events is now limited to prevent uncontrolled memory consumption:
- Added configuration for maximum number of log records;
- In case of log overflow, added configuration how to handle it (stop logging, remove old items, log to a file);
* Added BitLocker properties indication for an incompletely decrypted BitLocker;
* In the scan finalization GUI now added more detailed indication of currently running operations, including number of found files;
* Added support of empty folders in scan results (to recover folder structures without files);
* NTFS file system scan:
- Added support of recovery of empty files, including files with only named data streams;
- Added procedure of restoration of lost file placeholders when there is no file descriptor (only a reference from a directory index);
* EXT3/4 file systems:
- Added support of empty folders and files of zero size in scan result;
- Fixed few issues with processing of journal and file names recovery;
* In disk imager: added support of import/export for lists of imaging ('include'/'exclude') fragments.
Angel Data Recovery
PostPosted: January 30th, 2023, 10:08
What's new in version 9.13:
In sector state map tab UI:
- Added standard control toolbar;
- Added function of saving map information to a file in UFS Explorer SDMF format (any source format);
- Added option of saving map in inverted state;
Added 'Manage all tasks' dialog to set up automatic copying from more than one file at once;
Added 'set caching' function in RAID builder dialog (including 'set to all');
Added special tool for mass setting of saving processed data from multiple storages;
For Dynamic HTML report now added support of custom HTM-templates (for report 'branding'/'customization'):
- Added sample templates to installation for demonstration of dynamic report customization;
- Added 'include folders' flag to file search function;
Microsoft Storage Spaces:
- Added support of 'type 6' virtual disk descriptor records;
- Fixed issue with support of 'type chunk' records (format version 3 and above);
Fixed issue with resumption of 'scan status' (ssdb) of RAID-Z scan;
Added settings for handling map-defined virtual defects;
When loaded associated map of defects for disk image, default 'defect' action is now 'virtually reproduce defects';
BitLocker properties (Recovery key) now has link to open Microsoft Cloud storage of recovery keys;
XFS file system scan: fixed couple of issues with save/resume scan and deleted file names recovery;
BtrFS scan:
- Fixed issue with assembly of multi-component file system;
- Better recovery of virtual address space when virtual address space tree is lost;
Fixed detection of LDM on GPT meta partition at long offset.
PostPosted: March 7th, 2023, 10:07
What's new in version 9.14:
* All file reports have been reworked to support splitting into files of roughly a fixed, configured size;
* Dynamic HTML report:
- Added 'recalculate folders capacity' sub-report type (for reports, saved from file system with no scan);
- Fixed numeric overflow bug in object IDs;
- Fixed issue with column sort function in search result;
* Added experimental support of Drobo Cache - for attempts to recover damaged blocks from cache;
* VMware Workstation - encrypted VMDK files:
- Added decryption of split-VMDK files (they have to be opened from encrypted VMDK metadata file);
- Added support of encrypted delta-files (including split) - setting up as a delta, indication of the parent file hint;
* Added support of custom LaCie/WD AnyRAID LUKS encryption:
- Added password transform function (when possible to apply);
- Initialization vector 'cbc-plain:sha1' is considered as 'cbc-plain' (32bit);
* Microsoft Data Deduplication:
- NTFS access: added support of non-deduplicated modification of deduplicated files via copy-on-write bitmaps;
- ReFS access: modified procedure for handling deduplicated files and added support of non-deduplicated modifications on them;
- File open procedure: is now much optimized for speed (by reducing the number of verifications);
- In scan: optimization for completion speed, fixed bug with 'hotspots' interference ('pending modifications' not yet supported);
* LUKS2 decryption: fixed issue with decryption of volumes with 4K sector size;
* Saving disk image files to E01 (EWF) format:
- Fixed bug with sudden appearance of extra blocks at the end of file;
- Added special warning message about 'correct completion' of disk image (padding with zeros);
- Added progress indication for file finalization (when imaging is aborted) with ability to abort correct completion;
* HFS+ scan: better reconstruction of lost folder names from journal;
* ExFAT scan: removed duplicate 'green'/'yellow' file systems in result;
PostPosted: April 14th, 2023, 9:01
What's new in version 9.15:
* In the 'Open thin-provisioned volume' tool:
- Added a function to open a volume in case of partial metadata damage ('ignore errors' mode);
- Added support of 'thick' volumes (with pre-allocated space);
* In the general storage decryption dialog: added support of constant initialization vector;
* Some optimizations of GUI for default (double-click) actions (to decrypt encrypted storages etc.);
* Some optimizations of 'Drives/Bridges security' tool (to speed-up detection, get rid of unnecessary volume unmounts etc.);
* RAID5 and RAID6: added an option to generate virtual defect blocks explicitly instead of using pattern fill (to sort good/bad files basing on defects);
* RAID builder GUI:
- Added support of RAID50 and RAID60 as separate RAID types;
- Pattern display grid is also adopted to RAID50 / RAID60;
- Added a configuration parameter for virtual reproduction of defect blocks on over-degraded areas (RAID levels 5, 6, 50 and 60);
- Added stripe of size 512 bytes to the stripe size selection list;
* Drobo RAID: added bitmap support for cache, fixed bug with adaptive RAID reconstruction;
* Added support of direct access to SMART/identification of NVMe storages on USB adaptors with Realtek, Asmedia and JMicron bridge chips;
* Under Linux: added support of direct access to NVMe SMART/identification information;
* In SMART monitor:
- NVMe: added indication of maximum (warning) temperature and current TBW (terabytes written) basing on NVMe SMART;
- SAS: added displaying of G-list size for SSD; also added TBW estimation (both SSD and HDD), basing on Log Page 02h information (WRITE log);
- SATA SSD: added displaying of TBW estimation using F9h SMART attribute, when available;
* Under Windows: added system (OS) file cache size to software settings - to control system memory use when working with image files;
* Few corrections to FAT/FAT32 scan procedure (to support several previously unsupported metadata damages);
* Added support of several recent digital cameras (RAW formats) to embedded viewer.
PostPosted: May 15th, 2023, 11:20
What's new in version 9.16:
* In disk imaging task (on demand imaging):
- All supported data protection/write-blocker adaptors are now 'recommended' type of source (storage protection from activity of running OS);
- Fixed several bugs (retries, 'source loss' condition etc.);
- Changed default configuration for Tier1 imaging (no extra retries, enabled two-pass imaging);
* Added sharing of 'file type check' information from scan result to filtered scan result;
* Added possibility to enable log file (journal) scan for quick scan of NTFS file system (default is 'off');
* EXT3/4 (In 'quick' scan/indexing): processing of journal is now made optional (default is 'off');
* Intel Optane: reworked cache mapping algorithm and added support of linear (spanned) cache zone;
* RAID50/60 support: Added reverse address translation for RAID builder GUI;
* iSCSI target (server):
- Fixed compatibility issue with open-iscsi client (iscsiadm);
- Added proper reproduction of defect blocks via iSCSI (verified with default Windows initiator and Linux open-iscsi);
* Drobo BeyondRAID: speed-up of general read/scan operations (especially for non-allocated storage space);
* Added support of hardware RAID on JMicron chips (including QNAP TR extension boxes);
* Added recognition/support of certain WiebeTech (CRU) and Tableau (Opentext) data protection bridges/adaptors;
* In the general disk imager (image at once):
- Speed optimization for EWF (E01) image file creation;
- Speed optimization for SDLSP format (especially on a LAN target);
- Faster (optimized) processing of file system journal - by caching it to memory;
- Faster 'open' for existing big EXT3-4 volumes;
* Fixed issue with support of SATA M.2 SSD via Realtek USB-to-NVMe bridge chip;
* Added support of drives identification and SMART access on IEEE 1394 (FireWire) connection;
* In embedded viewer:
- Added several unsupported camera raw formats (and fixed couple of related bugs);
- Significantly reduced number of access attempts to storage when defect block is detected.
PostPosted: May 15th, 2023, 11:59
Great Work Yuriy :-)
PostPosted: June 20th, 2023, 12:41
What's new in version 9.17:
Added basic function of volume address translation to a file system file/folder and the offset inside;
In RAID Builder: added tool to build 'a copy of RAID' - it allows to build several different configurations from the same source;
Added support of older 3Ware RAID metadata format for automatic RAID construction;
Added support of message activation in file copying message log:
- Activation of file-related event now opens container folder and selects the associated file;
- When events are automatically redirected to a file (due to log overflow), activation of redirection event record will open the log file;
In disk imager:
- Changed log format for better compatibility to forensic imaging (also included information about forensic bridge, imaging status etc.);
- Better handling and indication of image write errors;
SMART tool:
- Refresh operation is made asynchronous to prevent UI from freezing on long updates;
- Proper indication of SCSI 'not ready' status (including running FORMAT UNIT command);
Reworked file copying with replacement of 'unsafe symbols' (such as '/', '?' etc.):
- Under Windows: unsupported symbols on a source file system are changed to special Unicode symbols (macOS-style) on a target;
- Under Linux: all 'unsafe symbols', except '/' are now allowed;
- Under macOS: all 'unsafe symbols', except '/' and ':' are now allowed;
- When source file system contains macOS Unicode replacement symbols, they are changed to 'original' ones in the user interface;
Minor fix to ReFS3 file system (to support a variation of metadata format);
Fixed bug with EFS-encrypted files, recovered with full-disk scan stage;
Fixed bug scanning volumes with compressed files on NTFS;
Fixed bug processing extended attributes on XFS file system;
Legacy HFS file system: now displayed and preserved file creation/modification dates.
PostPosted: June 20th, 2023, 13:43
In disk imager:
SMART tool:
Well,
Excellent Work As Always ,I am Still on 9.11
PostPosted: June 21st, 2023, 3:54
Amarbir[CDR-Labs] wrote:
Well,
You can get a discount to upgrade to the latest version when you're ready. :wink:
PostPosted: June 22nd, 2023, 9:53
Iurii,
am i short-sighted or there is indeed no way to see the version number on the download page? Neither the downloaded installer shows any sign of version number... at least not what i have noticed :s
Is there a way to get any previous release? I might have run out of the support period just now...
thx,
PostPosted: June 22nd, 2023, 11:06
PM sent.
Well,
PostPosted: June 24th, 2023, 14:47
pepe wrote:
Iurii,
thx,
Hello. Pepe
He has it on his official page a little hidden :D
https://www.sysdevlabs.com/product.php?id=ufsxp#changelog
If you go to the "Changes log" section you will see all the changes of each version and their download links.
PostPosted: July 1st, 2023, 14:44
cool, thanks!
PostPosted: July 27th, 2023, 15:42
What's new in version 9.18:
Added support of 'data entropy' map:
- In disk imager, added possibility to save 'data entropy' map during imaging (low and high resolution);
- Added option for visualization of entropy map during imaging (with synchronization to imaging and to map of defects);
- Added possibility to visualize saved 'data entropy' map via 'Enable a block status map' tool;
In map visualization GUI:
- Added possibility to change dynamically the size of grid cells;
- Added support of statistics on 'data entropy' map;
In RAID builder:
- In context menu of selected set, added 'To a new RAID' tool to create a RAID on a subset;
- Added also comparison of selected items via 'Compare storages' context menu option;
Added support of multi-volume configurations of very old Drobo DAS devices;
In disk imager:
- Changed two-pass imaging to multi-pass imaging by adding optional one or two pre-imaging stages (with no retries on defects);
- Added optional pre-imaging stage 0 - to quickly skips slow and damaged areas for fast imaging of 'healthy' areas;
- Added one more pre-imaging stage to run on slow areas and to skip areas with defects (postpone them to the 'normal' stage);
- Added possibility to override number of retries and read timeout for the final imaging stage;
Built-in viewer now supports displaying the contents of certain archive file formats:
- Added support of Zip, TAR, GZip and BZip2 archive container formats (including .tar.gz, .tar.bz2);
- Added content decompression for Deflate, Deflate64, BZip2, LZX, LZMS, LZMA, MS XPress and plain content streams;
- Added limited support of Windows IMage (WIM) file format (only individual files in current format);
- Support of preview of contained files;
In 'file search' result: added missing color and file status indication;
Added displaying of the number of files in scan result folders;
Disabled the indication of the folder metadata size (to avoid confusion with the size of contained files);
- Added possibility to re-enable this function in the software settings;
Fixed issue displaying color progressive (one scan per component) JPEG images as greyscale;
Reworked support of ISO9660 file system.
PostPosted: October 11th, 2023, 2:59
What's new in version 10.0
* Archive viewer:
- Added support of MSZIP decompression schema;
- Added partial support of CAB file format;
* Fixed bug with support of LUKS2 decryption;
* Added support of decryption of Synology full volume encryption;
* Reworked design of all static HTML reports;
* Reworked menu structure for disk imaging tools;
* Added 'media manager' function:
- Optional detection of supported connected 'complicated' media devices (dedicated UI section for recognized media devices);
- Automatic assembly of mdadm RAID and LVM;
- Assisted (automatic) access to shared folders, iSCSI volumes, snapshots etc.;
- Automatic decryption of supported encrypted folders and containers;
- Support of QNAP (QTS 4.3 to 5.1), Synology (DSM 6.2 to 7.1) and Apple AirPort storages.
* Optional 'dark theme' in user interface;
- Automatic recognition of the dark/light theme of the system under Windows and macOS;
- Added the ability to independently configure the color theme of the program;
* Object properties dialog now includes explanation to custom colors of objects in UI;
* Added new scan type: 'Only the current file system' - to increase 'completion' speed and reduce memory usage;
* Fixed issue with proper recognition of DDF1 RAID10 configuratios on some controllers;
* Fixed several quality-related issues in raw recovery.
PostPosted: November 3rd, 2023, 8:15
What's new in version 10.1:
* Added support of RAID0+1 configurations of HP SmartArray controllers (version 1 metadata);
* Added support of RAID0 configurations on RAID components of different sizes (dynamic adjustment of rotation);
* Added support of iSCSI file storages on ASUSTOR NAS (format of index+data, via Media Manager);
* In LUKS decrypt: added support of 'Base64 decode' transform to accept 'rkey' binary passwords of Synology NAS;
* Added support of WD MyCloud backup keys for storage decryption;
* In file viewer: added 'quick preview' for disk images and virtual disks of common formats and with most used file systems;
* In Media Manager:
- Added support of ASUSTOR NAS devices (shares, snapshots, iSCSI target files, encrypted shared folders);
- Added support of WD MyCloud NAS (OS 5: PRO, EX2 Ultra etc.) storages;
- Added support of legacy WD MyCloud Home series storages;
- For MyCloud Home storages, added proper indication of user name for 'auth' container folders;
- Fixed bug with support of GPT on Synology NAS;
* Reworked ReFS file system support module:
- Replaced 'mapping of file segments' with 'IO virtualization' to support segmentation and double indirection (optional, ReFS 3.9 and later);
- In 'access mode': added experimental support of ZSTD and LZ4 file compressions;
- In both 'access mode' and 'scan result': added support of 'redirected' file metadata (this fixes displaying of some files as 'folders');
* Removed imaging optimization for AVHDX/SDLSP files with enabled 'base' files (which are used as a 'delta');
PostPosted: December 4th, 2023, 10:24
What's new in version 10.2:
* Virtual sector size transformation: added support of conversion of 4160- and 4608-byte blocks to 4096 bytes;
* Plain (flat) disk images now have native support of extended sector sizes (defined via the 'Virtual sector size transformation' tool);
* For QNAP NAS: added support of LUKS decryption using backup key files (via 'Media Manager' GUI);
* 'Open device (advanced)' function now has setting for maximum IO block size (to support limitations of some adaptors);
* In disk imager (ATA mode) - fixed issues with read errors caused by mis-aligned buffer;
* SDLSP format now has native support of extended sector sizes (such as 520, 528, 4160 etc.);
* Saving images from SDLSP and plain files with extended sector size enable automatic conversion to standard sector size;
* In 'Media Manager': added support of TerraMaster NAS (shared folders, iSCSI, etc.);
* XFS file system: added support of 'object type in directory entry' extended feature for XFS metadata version 2;
* UFS file system: added support of sparse files;
* Increased software stack size to support much larger depth of directories nesting;
* In Explorer, introduced additional 'yellow' state for files found with 'raw recovery'.
