Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: mhdd lookalike for linux ?
PostPosted: July 10th, 2013, 18:51
Hi
When I do the ./build.sh
I get this:
./build.sh: 3: ./build.sh: cmake: not found
To install, type
make install
It will install executable `whdd`.
Wich command now?
ACELab partner
PostPosted: July 11th, 2013, 1:49
if you are in the correct directory of the software you are installing, usually you would type:
make
then:
make install
sometimes before the make you would type ./configure
read the documentation...
cheers
PostPosted: July 11th, 2013, 13:58
pclab wrote:
Hi
I get this:
Install cmake package in the standard way for your distro. Note that cmake version must be 2.8.8 or higher.
PostPosted: July 12th, 2013, 2:47
Will this software function correctly in a VM? I am re-building my lab and it is easiest option for me at the moment as I have 1 Laptop I can use right now.
cheers
PostPosted: July 12th, 2013, 3:22
cheers
Which kind of VM you're going to use?
Depending on VM implementation, and VM settings, ATA operation mode may not work.
I'll be happy to hear from you the results.
PostPosted: September 10th, 2013, 7:03
WHDD-2.1 release.
Changes since 2.0.1:
Enhanced smart, smart_noreverse copying strategies;
Introduced new copying strategies skipfail, skipfail_noreverse;
Introduce journaling of copying and automatic resuming of interrupted copying;
Support procedure parameters overriding by ~/.whddrc config file;
Several bug fixes.
Having no time and willpower to document thoroughly all new features…
What about ~/.whddrc config file: add a line
procedure_name.parameter_name=value
to omit dialog, or
procedure_name.parameter_name.suggest=value
to override default suggestion in dialog.
Spaces are not allowed currently. Line is matched from the beginning. So any character, like #, at the line beginning makes it a comment.
http://whdd.org
PostPosted: December 15th, 2013, 9:56
Hi
I have being watching this tools that seems very promising.
Today I have installed it into my system and it went OK.
But when I try to check my HDD's it says Init Procedure Fail.
Why is this?
ACELab partner
