| Low-level format and mapping out bad sectors http://forum.hddguru.com/viewtopic.php?f=7&t=10060 |
Page 1 of 1 |
| Author: | rickelwell [ October 5th, 2008, 10:21 ] |
| Post subject: | Low-level format and mapping out bad sectors |
I thought a low-level format should map out bad sectors so the OS does not "see" them. This does not appear to be happening with your low-level formatting tool. I formatted a disk using Windows XP disk management and it correctly reports 253,000 KB in bad sectors and a reduction in total disk space, as expected. Then I formated with your low-level formatting tool, Windows XP now reports 0 KB in bad sectors and no reduction in disk space. I think your low-level formatting tool is dangerous and should not be used! If I were to continue using this disk, as-is, I would experience file corruption because the bad sectors were never identified and mapped out by your low-level formatting tool. My experience with low-level formatting is that you typically execute microcode on the HDD controller which maps out the bad sectors. The result is a reduction in total disk space and the OS reports 0 KB in bad sectors. I think you should rename your low-level formatting tool to "advanced format tool". |
| Author: | rchadwick [ October 5th, 2008, 12:41 ] |
| Post subject: | Re: Low-level format and mapping out bad sectors |
rickelwell wrote: I think your low-level formatting tool is dangerous and should not be used! I think you shouldn't use it. |
| Author: | rickelwell [ October 5th, 2008, 14:34 ] |
I guess for most people your low-level formatting program will work fine if there disk is good. Plus your program is free!! However, I have an old disk that corrupts files due to bad sectors. I need to map out these bad sectors somehow. Hmmm... they're must be a way.... |
| Author: | shahij [ October 6th, 2008, 16:23 ] |
hmmmm check it... http://forum.csebd.net/viewtopic.php?f=13&t=44 http://forum.csebd.net/viewtopic.php?f=13&t=19 |
| Author: | skozzy [ November 23rd, 2008, 20:06 ] |
The idea of this tool is to blank the drive and the data to the maps of bad sectors this allows many of us with software based errors to get a fully working HDD, after using it you use another program to scan for errors like HDDScan. I'm sure it was in the instructions somewhere about this. |
