| File Repair on Jpegs http://forum.hddguru.com/viewtopic.php?f=7&t=10516 |
Page 1 of 1 |
| Author: | simon [ November 19th, 2008, 13:46 ] |
| Post subject: | File Repair on Jpegs |
Can anyone tell me what the best software is for jpeg repair. thanks Simon |
| Author: | craig6928 [ November 20th, 2008, 4:19 ] |
| Post subject: | Re: File Repair on Jpegs |
there not many programs that can total fix jpegs are you getting draw line failed. if so that because of the program compressing the file everytime its opened. |
| Author: | simon [ November 20th, 2008, 11:40 ] |
I've got thumbnails that are showing up but when I click on them they open different pictures. I also have a lot of files with thumbnails but when I click on this nothing comes up. Simon |
| Author: | beto [ November 20th, 2008, 12:23 ] |
U should be check on first "headers" did u check it? wich was the problem on first from the hdd" formatted", " bad sectors" " bad heads"? |
| Author: | simon [ November 20th, 2008, 12:36 ] |
when copying files from a main pc drive to a external drive the copy process failed. From there the folders with all the pictures disappeared. I imaged the drive and used get data back and recovered all the pictures but many of them seem missing, damaged and misrepresented. sime |
| Author: | dick [ November 20th, 2008, 13:14 ] |
Hi, sorry but its unclear to me which drive you are working on. Main pc or external? Take a look at the files you have recovered so far. Check and compare the file sizes. Are many files showing 0 bytes? |
| Author: | simon [ November 20th, 2008, 13:15 ] |
i'm running off the destination drive, not the new one. I used my ddi to do a complete clone of the drive. There are many files with 0 file size. sime |
| Author: | dick [ November 21st, 2008, 3:54 ] |
Simon, can you clarify what went wrong and what you have done since? From your description I understand you have since imaged your main pc hard disk to what was the external disk and you are now trying to recover files from the image? Sorry but I can see 2 or 3 different scenarios here and it needs to be clear. Recovering files of a 0 bytes size usually means they have been overwritten. |
| Author: | pcimage [ November 21st, 2008, 4:41 ] |
From the sounds of what's happening here, I would use something like "Recover My Files". It searches for file signatures and then attempts to ressurrect the file structure, and with this software it give you a "running commentry" of all raw files recovered so far, and you can view them at a good size and evaluate their validity. |
| Author: | craig6928 [ November 21st, 2008, 7:38 ] |
try this program out this might help you out but it runs in dos http://www.cgsecurity.org/wiki/PhotoRec |
| Author: | craig6928 [ November 21st, 2008, 7:44 ] |
this is another program we use for repairing some jpeg files your have to buy it but you can test your files before purchasing it http://www.hketech.com/JPEG-recovery/index.php Do you find that some photos recovered by digital photo recovery software are corrupted, e.g.: Splits into two (or even more) parts, and In between there is part of another photo, and The color of the lower part(s) may be changed, and There is a shift of the contents of the photo if you dont want to buy the product yet send me one of the corrupt files and i try and fix it for you |
| Author: | craig6928 [ November 21st, 2008, 7:55 ] |
allso this program might help you if the files are corrupted http://www.irfanview.com/ it supports most images and if it dedect image with wrong extention it ask if u want to rename. |
| Author: | simon [ November 21st, 2008, 21:28 ] |
thanks guys' very helpful, I'll do some downloading and testing. sime |
| Author: | craig6928 [ November 22nd, 2008, 2:56 ] |
how your getting on with the recovery did any of these programs help you out whooops i spelt detect wrong allnight recovery work not much sleep |
| Author: | simon [ November 22nd, 2008, 11:31 ] |
I'm just doing recover my files right now. It looks like it'll be going for a day or two... stay tuned. |
| Author: | drc [ November 22nd, 2008, 17:02 ] |
I'm interested to know how well photorec works. I use that guys other software, TestDisk, fairly regularly. |
