 Post subject: Software to fix harddisk not known by BIOS
PostPosted: December 10th, 2008, 11:58
Is there away to fix a hard disk which is not known by bios? My dell latitude C640 laptop was sufferin from overheating (fan not workin n so it was restarting.) I took the hard disk out to save my important data but it was not recognized at all. Anyway to fix it?
 Post subject: Re: Software to fix harddisk not known by BIOS
PostPosted: December 10th, 2008, 19:46
Did you have a bios password enabled on the c640? if yes, the password transfers over to the hard-drive as well and will need to be removed first.
If no, then your drive is probably failing, mechanical or firmware.
PostPosted: December 11th, 2008, 9:16
more likely a damaged board on the drive that has failed
first option is match up the board
PostPosted: December 12th, 2008, 5:52
Not ATA password as disk is not recognised at all. If your laptop was overheating then possibly the PCB is damaged. Or possibly worse, but as this is NOT a logical failure there is no software available for a quick fix. Consult a professional, and at the very least get an accurate diagnostic.
cron
