Software to fix harddisk not known by BIOS
http://forum.hddguru.com/viewtopic.php?f=7&t=10701
Author:  ipanda [ December 10th, 2008, 11:58 ]
Post subject:  Software to fix harddisk not known by BIOS
Is there away to fix a hard disk which is not known by bios? My dell latitude C640 laptop was sufferin from overheating (fan not workin n so it was restarting.) I took the hard disk out to save my important data but it was not recognized at all. Anyway to fix it?
Author:  Russwinters [ December 10th, 2008, 19:46 ]
Post subject:  Re: Software to fix harddisk not known by BIOS
Did you have a bios password enabled on the c640? if yes, the password transfers over to the hard-drive as well and will need to be removed first.
If no, then your drive is probably failing, mechanical or firmware.
Author:  craig6928 [ December 11th, 2008, 9:16 ]
more likely a damaged board on the drive that has failed
first option is match up the board
Author:  hddguy [ December 12th, 2008, 5:52 ]
Not ATA password as disk is not recognised at all. If your laptop was overheating then possibly the PCB is damaged. Or possibly worse, but as this is NOT a logical failure there is no software available for a quick fix. Consult a professional, and at the very least get an accurate diagnostic.
