| Rewrite Firmware of 7200.11? http://forum.hddguru.com/viewtopic.php?f=7&t=11027 |
Page 1 of 1 |
| Author: | sumhdd [ January 17th, 2009, 8:32 ] |
| Post subject: | Rewrite Firmware of 7200.11? |
Hi, in a moment of panic i flashed the firmware of my 7200.11 from SD15 to AD14 with this update (h**p://support.seagate.com/ad14disty/AD14-AllMoose.zip). After that, i saw that the update was provided for firmware-version SD14 and not explicit for SD15. The updateprocess do not failed. there was no error or something like that. now my question: is the AD14-Firmware-Version a problem for my harddrive? at the moment, windows 2k3 server do not boot when the updated-drive ist connected. thanks for help. |
| Author: | N.C. [ January 17th, 2009, 8:53 ] |
| Post subject: | Re: Rewrite Firmware of 7200.11? |
Hi, After a moment of panic, the recovery price will be double or more, i think. Additionally, now 1/10 part of the DR companies can do the DR before You missed up the SA. I suggest to seek for a reallly professional help, if You want your data back... Regards, Janos |
| Author: | sumhdd [ January 17th, 2009, 9:07 ] |
doesn't there exist another way? maybe flash the fireware again back to the old one with the old version? the question is: who can provid me SD15 as an flashable version? |
| Author: | sumhdd [ January 17th, 2009, 9:29 ] |
when i boot from a live-linux-cd, i can get the following infos: Quote: Model=ST31000340AS , FwRev=AD14 , SerialNo= 9QJxxxx Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs RotSpdTol>.5% } RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=4 BuffType=unknown, BuffSize=0kB, MaxMultSect=16, MultSect=?16? CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=1953525168 IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: mdma0 mdma1 *mdma2 UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5 udma6 AdvancedPM=no WriteCache=enabled Drive conforms to: unknown: ATA/ATAPI-4,5,6,7 * signifies the current active mode i think, that's signal Quote: Error reading bootsector: Input/output error Failed to mount '/dev/sdd': Input/output error NTFS is either inconsistent, or you have hardware faults, or you have a SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows then reboot into Windows TWICE. The usage of the /f parameter is very important! If you have SoftRAID/FakeRAID then first you must activate it and mount a different device under the /dev/mapper/ directory, (e.g. /dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation for the details. if some can help me to reflash the firmware to SD15, it would be so wunderful |
| Author: | N.C. [ January 17th, 2009, 9:43 ] |
i am sorry, but this is not so simple like a cell phone with one flash chip.... The drive's firmware are in more places including the SA in the platters! The firmware contains a lot of critical calibration and adaptive parts. You have mixed up the SA and created a really bad state. Forget it, to someone can help you to fix your drive! Only a really skilled pro can help you if it is still possible... Janos |
| Author: | sumhdd [ January 17th, 2009, 9:57 ] |
mhmm...bad news. on other question: should the firmware-update-software actually check, if the installed hdd has the right firmware? if yes, I wonder why there no error occured... |
| Author: | N.C. [ January 17th, 2009, 10:08 ] |
sumhdd wrote: mhmm...bad news. on other question: should the firmware-update-software actually check, if the installed hdd has the right firmware? if yes, I wonder why there no error occured... I think, only the authors knows the correct answer for this question. I can imagine, the updater only check for the phisical parameters, like the new fw can fit into the sa, or similar.... I don't think, this even cares about the P/G lists or similar, so the error logs can be overwritten too. Janos |
| Author: | drc [ January 17th, 2009, 16:40 ] |
Use MHDD, see if you can scan the drive at all |
| Author: | sumhdd [ January 22nd, 2009, 12:24 ] |
jeha!!! i reflashed my hdd-firmware today and?!?!?! IT WORKS!!! |
| Author: | dj_def [ February 17th, 2009, 20:57 ] |
When the drive is in that state you can't go on after the BIOS screen. Hi, how did you reflash it? Can you post the procedure? |
| Author: | seeprakash [ February 17th, 2009, 21:49 ] |
Mr.sumhdd, That's news what you have posted up above here !!! Please let the world know the process ...how was this achieved ... Cheers, |
| Author: | Doomer [ February 17th, 2009, 23:15 ] |
He just used SD1A FW update from Seagate site |
| Author: | dj_def [ February 18th, 2009, 4:38 ] |
Yesterday night I updated the firmware. I downloaded the image from the seagate site (it can be downloaded after validation of serial number, if the drive is "affected"). As all of you know, the drive in that conditions (after being reflashed with AD14 firmware) cannot go on the BIOS screen. I just connected the power cable after the bios screen and the red light in my PC case turned off. The update process finished successfully, the PC powered off. When I pushed the PC power button I noticed my drive was working again I must say that in the seagate technical support chat somebody told me that I had to do a RMA and somebody told me that my drive was bricked and I had to buy another one. I am happy I didn't listen to them. Thanks very much to sumhdd and good luck to the others. |
| Author: | person2009 [ February 26th, 2009, 14:37 ] |
Why did you mess with the firmware in the first place? |
| Author: | ephraim2 [ March 11th, 2009, 2:35 ] |
HI FRIENDS I HAVE SAME SEAGATE ST3500320AS, S/N 9QM2458X, FIRMWARE SD15, DATA CODE 08373, 500GB, SATA, NOT WORKING, NOT DETECTED BY BIOS. SPOKE TO SEAGATE AND THEY SAID THAT DRIVE LOCKED OT FIRMWARE PROBLEM. AFTER LOOKING IN GOOGLE WE FOUND THAT THERE IS A PATCH FOR FIRMWARE. DIDN'T FIND IN SEAGTE SITE. CAN ANYBODY BE SO KIND AND SEND ME THE FRMWARE UPDATE. IF ANYBODY CAN SEND THE PROCEDURE ALTHOGHT I COLLECTED SOME DATA, WILL BE GREAT. I'LL APPRECIATE YOUR ASSISTANCE. EPHRAIM |
| Author: | datasolution [ March 28th, 2009, 13:42 ] |
hi i m sachin from india ahmedabad. after long search on net finally i got this firmware update utility. http://seagate.custkb.com/seagate/crm/s ... cId=207931 check this page just input your hdd's data and u will find does yr hdd has firmware problem or not and if there is firmware problem then go to the forth step and download yr firmware upgrade software enjoy |
