 Post subject: Windows registry fixing (question)
PostPosted: January 27th, 2009, 6:35
Hello gurus,
Somebody know about a downloadable registry fixer wich can work on external file if the windows can't boot at all?
Thanks,
Janos
 Post subject: Re: Windows registry fixing (question)
PostPosted: January 27th, 2009, 6:52
N.C. wrote:
Hello gurus,
Thanks,
Janos
Avast registry tool can export and import registry from crashed system as long as file system is still intact
My Forum
PostPosted: February 1st, 2009, 4:09
Also, last time I checked UBCD for Windows can 'mount' a registry, and then you can run whatever tool you'd like. Used to use it all the time for virus/spyware fixes.
PostPosted: February 1st, 2009, 6:46
Thanks for everybody for the usefun answers! :)
Janos
PostPosted: February 6th, 2010, 0:46
usually, if the XP systems i repair have trashed registry hives, i just use a bootable CD (Bart, UBCD.. anything with a copy / rename file command or tool) & use the last snapshot from the system volume restore (repository),, its like 4 files , sam, Security, system, software. just copy over to c:\windows\system32\config & rename accordingly, any questions just ask & i will explain a little better (only works if system volume restore has not been turned off)
