| Windows registry fixing (question) http://forum.hddguru.com/viewtopic.php?f=7&t=11106 |
Page 1 of 1 |
| Author: | N.C. [ January 27th, 2009, 6:35 ] |
| Post subject: | Windows registry fixing (question) |
Hello gurus, Somebody know about a downloadable registry fixer wich can work on external file if the windows can't boot at all? Thanks, Janos |
| Author: | cryoborgofthevenus [ January 27th, 2009, 6:52 ] |
| Post subject: | Re: Windows registry fixing (question) |
N.C. wrote: Hello gurus, Somebody know about a downloadable registry fixer wich can work on external file if the windows can't boot at all? Thanks, Janos Avast registry tool can export and import registry from crashed system as long as file system is still intact |
| Author: | rchadwick [ February 1st, 2009, 4:09 ] |
Also, last time I checked UBCD for Windows can 'mount' a registry, and then you can run whatever tool you'd like. Used to use it all the time for virus/spyware fixes. |
| Author: | N.C. [ February 1st, 2009, 6:46 ] |
Thanks for everybody for the usefun answers! Janos |
| Author: | DrFaustus [ February 6th, 2010, 0:46 ] |
usually, if the XP systems i repair have trashed registry hives, i just use a bootable CD (Bart, UBCD.. anything with a copy / rename file command or tool) & use the last snapshot from the system volume restore (repository),, its like 4 files , sam, Security, system, software. just copy over to c:\windows\system32\config & rename accordingly, any questions just ask & i will explain a little better (only works if system volume restore has not been turned off) |
