 Post subject: byte swap
PostPosted: April 17th, 2009, 16:01
Hello gurus,
Somebody can point me to an free program wich can do the byte swap?
This is too easy to be a challange for writing it. :mrgreen:
Thanks,
Janos
 Post subject: Re: byte swap
PostPosted: April 22nd, 2009, 13:55
Any decent hexadecimal editor should have the function. I am pretty sure Winhex can do that, can I ask what you want to byteswap for?
PostPosted: April 22nd, 2009, 14:42
A rom image saved with calypso board, but from different brand. (wd)
PostPosted: April 22nd, 2009, 14:50
Right, Winhex->edit->modify data.. 16/32 byte swap.
If you program in windows you can use the HostToNetworkOrder method. Else write your own :P
PostPosted: April 22nd, 2009, 15:09
Thanks, :wink:
PostPosted: April 22nd, 2009, 15:25
you could have programed it quicker than writing your message :shock:
PostPosted: April 22nd, 2009, 16:48
Yes, i know, but as i sad, this is too easy to be a challange... :mrgreen:
PostPosted: April 22nd, 2009, 16:49
btw guru,
Don't you read your PMs? 8)
