| byte swap http://forum.hddguru.com/viewtopic.php?f=7&t=12008 |
Page 1 of 1 |
| Author: | N.C. [ April 17th, 2009, 16:01 ] |
| Post subject: | byte swap |
Hello gurus, Somebody can point me to an free program wich can do the byte swap? This is too easy to be a challange for writing it. Thanks, Janos |
| Author: | littlendian [ April 22nd, 2009, 13:55 ] |
| Post subject: | Re: byte swap |
Any decent hexadecimal editor should have the function. I am pretty sure Winhex can do that, can I ask what you want to byteswap for? Regards |
| Author: | N.C. [ April 22nd, 2009, 14:42 ] |
littlendian wrote: Any decent hexadecimal editor should have the function. I am pretty sure Winhex can do that, can I ask what you want to byteswap for? Regards A rom image saved with calypso board, but from different brand. (wd) Thanks |
| Author: | littlendian [ April 22nd, 2009, 14:50 ] |
Right, Winhex->edit->modify data.. 16/32 byte swap. If you program in windows you can use the HostToNetworkOrder method. Else write your own Regards |
| Author: | N.C. [ April 22nd, 2009, 15:09 ] |
Thanks, |
| Author: | guru [ April 22nd, 2009, 15:25 ] |
you could have programed it quicker than writing your message |
| Author: | N.C. [ April 22nd, 2009, 16:48 ] |
guru wrote: you could have programed it quicker than writing your message Yes, i know, but as i sad, this is too easy to be a challange... |
| Author: | N.C. [ April 22nd, 2009, 16:49 ] |
btw guru, Don't you read your PMs? |
